Lennart Schultze
Rep Power: 8 ![]() |
Hello
![]() i have created Mesh for a Pipegeometry with Salome-Meca. Now i want to import the generated Mesh into Helyx-OS to use it for the CFD-Simulation. The possible file formats from Salome are not convenient for Helyx-OS. Has anyone a suggestion how i can import the Mesh? Best regards ![]() |
France - Alsace
What is the format exported from salome of mesh file, you can use hypermesh to convert file to another desired format. Best regards, |
Lennart Schultze
The file format is UNV. There are some more formats. But i can't import them into Helyx-OS
France - Alsace
This format can be read by Hypermesh. You can try. What do you need of start format for helyx-os ?
Lennart Schultze
When i want to choose the file, the file format is Block Mesh Dictionary and the Mesh files are not shown. But you can change the file format into all files and then choose UNV or something else. But when i choose the UNV nothing happens.
helyx-os, mesh, salome-meca |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Unable to import mesh on the CFX-Pre | jarrai | CFX | 1 | December 20, 2010 07:05 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
