[PyFoam] Problem with pyFoamPVSnapshot
Old   September 21, 2017, 10:19
Default Problem with pyFoamPVSnapshot
Pavel Rodin
Pavel Rodin is on a distinguished road
Hello everyone,
I started working with OpenFOAM not so long ago, but I already know a little about PyFoam.
Generally, I used 'pyFoamRunParameterVariation' utility and all was fine. But then I tried to use 'pyFoamPVSnapshot' utility and faced a problem, that I can't solve myself.
Here is some configuration info:
OS: Ubuntu 16.04.3 LTS
OpenFOAM-2.4.0
ParaView 4.1.0
PyFoam version: 0.6.7 (installed with pip)
I used the utility in the following way:
pyFoamPVSnapshot.py --latest-time --state-file=default.pvsm damBreak
The 'default.pvsm' file was prepared earlier through ParaView.
And here is what I got:
Executing PVSnapshot with pvpython trough a proxy-script
Warning in /tmp/pyFoamPVSnapshot_8h6vxh3u.py : Setting decomposed type to auto : Decomposed/Reconstruced correctly set. Nothing changed
PyFoam WARNING on line 110 of file /usr/local/lib/python3.5/dist-packages/PyFoam/Paraview/ServermanagerWrapper.py : Can't find expected plugin 'libPOpenFOAMReaderPlugin' assuming that correct reader is compiled in. Wish me luck Traceback (most recent call last):
  File "/tmp/pyFoamPVSnapshot_8h6vxh3u.py", line 4, in <module>
    PVSnapshot()
  File "/usr/local/lib/python3.5/dist-packages/PyFoam/Applications/PVSnapshot.py", line 51, in __init__
    **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/PyFoam/Applications/PyFoamApplication.py", line 436, in __init__
    result=self.run()
  File "/usr/local/lib/python3.5/dist-packages/PyFoam/Applications/PVSnapshot.py", line 493, in run
    views=pvs.GetViews()
AttributeError: 'module' object has no attribute 'GetViews'
Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed!
Error: Return code  127 executing /tmp/pyFoamPVSnapshot_8h6vxh3u.py
I tried to investigate these 'warnings' and came to the conclusion, that they are not critical (cause I've seen them in some presentations).
The line starting with "Inconsistency detected by ld.so.." also doesn't important. I ran 'pyFoamPVSnapshot' utility on another virtual machine with Ubuntu 14.04 (OF2.4.0, PV4.1.0, PyFoam 0.6.8.1) and got almost the same error except this line. But the error "AttributeError: 'module' object has no attribute 'GetViews'" still exist.
Any help would be appreciated.
Regards, Pavel
Pavel Rodin is offline   Reply With Quote
Old   September 22, 2017, 08:46
Pavel Rodin
<slowpoke mode deactivated>
Okay.. 'PVSnapshot.py' contains these lines:
import paraview.simple as pvs
but module 'simple.py' located in "~/OpenFOAM/ThirdParty-2.4.0/ParaView-4.1.0/Wrapping/Python/paraview/simple.py" really doesn't have 'GetViews' method. And I'm getting this AttributeError.
So the problem is ParaView version? And there is nothing I can do about it?
Old   September 22, 2017, 10:18
robob is on a distinguished road
Have you set a Text source with the content %(casename)s ?
robob is offline   Reply With Quote
Old   September 22, 2017, 11:13
Pavel Rodin
Don't quite understand what is about. I did not perform any additional actions after installation of PyFoam. Just played a bit with PYTHONPATH and set it following way:
export PYTHONPATH=$ParaView_DIR/lib/paraview-4.1/
But looks like it doesn't helped (and did anything at all).
Old   September 23, 2017, 12:49
Assistant Moderator
Bernhard Gschaider
Problem is that the API of Paraview was constantly changing. Especially before going to 5.0. I checked: the .GetViews()-line was written in March 2015. The latest Paraview version at the time was 4.3.1. So it might be possible that I worked with that or 4.2 but not with 4.1. I will have a look in the office whether I still have a 4.1 to see if that is a problem.
But since it was written that line works for me (currently use 5.4) so upgrading paraview to a more recent version might fix your problem (and you won't have to rely on me having time to look at that)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 25, 2017, 02:55
Pavel Rodin
Thanks for info, Bernhard.
Actually I was thinking about it too. I'll try another version of ParaView.
Old   September 26, 2017, 09:03
Pavel Rodin
So.. I tried to run 'PVSnapshot.py' utility with another version of ParaView (4.3.1) and here is what I got:
/home/prodin/Distrib/ParaView-4.3.1/lib/paraview-4.3/pvpython: error while loading shared libraries: libvtkPVServerManagerApplication-pv4.3.so.1: cannot open shared object file: No such file or directory
Error: Return code  127 executing /tmp/pyFoamPVSnapshot_pvtj9dn9.py
But the file named 'libvtkPVServerManagerApplication-pv4.3.so.1' definitely exists.
Is this some kind of permissions issue?
Last edited by Pavel Rodin; September 26, 2017 at 11:13. Reason: Found the answer to the question, but there is another question.
Old   September 27, 2017, 07:30
Pavel Rodin
I'm getting the same error with ParaView's version 5.2.0.
Seems I can't use ParaView as a portable program in that way (i.e. just changing the PATH variable).
But if I install Paraview using apt-get (currently of version 5.0.1), then I can make a screenshot through PVSnapshot utility.
Now I'm curious how to run the utility on a few case variations (e.g. after 'pyFoamRunParameterVariation.py' script execution).
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
