IHFOAM The Environmental Hydraulics Institute "IHCantabria"
Rep Power: 9 ![]() |
Greetings to all!
We are very proud to announce here the release of IHFOAM-GUI which contains IHFOAM developments during the last years and already included in release v1706. Additionally other physics not included in v1706 release are incorporated in the GUI, such as porous media flow (fully validated, published in four papers) and vegetation fields, (fully validated, published in two papers). ![]() IHFOAM-GUI has been designed following the request of many IHFOAM users to decrease the learning curve in the use of OpenFOAM® for coastal and ocean engineering. It is more than a standard OpenFOAM® GUI since it is especially designed to deal with free surface flows. The user will be able to set-up, in a short time, a numerical wave tank to analyze the interaction of waves with coastal and offshore structures. IHFOAM-GUI builds up the folders and the files needed to set-up a case guiding the user along several menus. Additionally, numerical proves can be inserted and post-processed along the GUI menu. ![]() IHFOAM-GUI is freely downloadable from the following link including a tutorial: http://ihfoam.ihcantabria.com/model/gui/ IHFOAM-GUI has been designed within the Coastal Hydrodynamics and Infrastructures Group in IHCantabria comprised by ten members. Future IHFOAM developments will be included in OpenFOAM® to be released by ESI Group and included in IHFOAM-GUI. IHCantabria developments has passed along a thorough validation with existing or tailored designed laboratory tests. Validation results are published in peer reviewed journals. Visit our web page for further details. We look forward to having feedback from you in this thread. Best regards, IHFOAM Team Environmental Hydraulics Institute “IHCantabria” - Universidad de Cantabria OPENFOAM® is a registered trade mark of OpenCFD Limited, producer and distributor of the OpenFOAM software via wwww.openfoam.com
http://ihfoam.ihcantabria.com/ Last edited by Tobi; September 22, 2017 at 02:15. |
Hua Zen
Rep Power: 17 ![]() |
Thanks for your work on the GUI. I can download the GUI manual successfully, but fail to download the GUI, can you check the links?
Hi Lin
We have just re-checked everything and it works wonderfully... if you can donwload the tutorial you should be able to download the code. Can we suggest you to try with another internet browser? If the problem persists, let us know and we will try to solve it. Best Regards, IHFOAM Team
http://ihfoam.ihcantabria.com/ |
Hua Zen
Thanks for your reply. I check the links again. I can download the ihFoam_mangroves.tar.gz ihFoam.tar.gz and Manual_GUI_IHFOAM_v1.pdf files, but for the IHFOAM-GUI_Ubuntu_1404_v1.15.tar.gz and IHFOAM-GUI_Ubuntu_1604_v1.15.tar.gz, I get the following error:
Website unreachable The page or website that you try to reach doesn’t exist or is unreachable. |
Brian Willis
Rep Power: 15 ![]() |
Also checked, and the links work as expected.
Hua Zen
I tried just now at the office, the download links are usable. Thanks for your confirmation.
Hua Zen
I'm interested in this GUI and want to give some feedback.
Since now the openfoam.com releases the binary version with the docker technology, the users could install it on any operating system, without bothering compiling from the source code. The centos system is used. But the GUI is built with ubuntu, this means if one want to use the GUI one have to compile the source code. It may be better to release the GUI versoins on a system compatible with the openfoam.com release. |
#8 | |
Thanks!!!
#9 |
Rep Power: 8 ![]() |
Just wanted to say that I am extremely interested in the potential of this model and the new GUI interface.
I'm a first time user both with IHFOAM and Linux. I have successfully installed and compiled both openFoam 1612+ and Paraview following the tutorial on the openFOAM wiki here. I am not yet comfortable enough to get the docker installation method working alongside the GUI so went ahead and compiled 1612+ locally as apparently it is also compatible. I am having an issue trying to execute any of the openFoam commands from within the GUI. For instance, following the GUI tutorial i am faced with the following error upon trying to execute the blockMesh command inside the StokesV interFoam example. /bin/sh: 1: blockMesh: not found The same issue persists for any of the other commands that are executed. It seems to me as some kind of path error related to the way the GUI is using the shell but I do not have the experience to figure this out. Has anybody faced this issue or know how to go about solving it? Just so you are aware the blockMesh command works fine outside of the GUI interface. Regards, Toby Last edited by toby.jhnsn; October 4, 2017 at 04:39. |
#10 | ||
Hi Toby,
Check section 2.3 in the GUI-Manual: http://ihfoam.ihcantabria.com/IHcode..._IHFOAM_v1.pdf Best Regards, IHFOAM Team
#11 | |
As part of the openFoam installation i was required to set up an alias in ~/.bashrc to the openFoam bashrc file to load the correct shell environment for openFoam. Could this have anything to do with the issue? |
#12 | |
Hi Toby,
In my case: ~/OpenFOAM/OpenFOAM-v1706/ (If you check that folder, you should see: "Allwmake" "applications/" "bin/" "build/" "BuildIssues.txt" "COPYING" "doc/" "etc/" "platforms/" "README.md" "src/" "tutorials/" "wmake") Did you compile OpenFOAM or do you use a pre-compiled version? Which version of OpenFOAM are you using? Are you using Ubuntu-14.04 or Ubuntu-16.04? Regards, IHFOAM Team
#13 |
Ok, the Openfoam folder path has been provided correctly. I am running Ubuntu 16.04 and compiled openFoam myself following the wiki guide that I listed previously. There does not seem to be any issue running openFoam outside the GUI.
Have you referenced any additional paths to the openFoam bashrc file in either your ~/.basrc or ~/.profile files? |
#14 |
As an update to my issues, I managed to get the GUI to work. The issue was entirely my fault and due to permission errors on the ~/openFOAM folder. I recompiled the entire package from scratch and no longer have this issue.
#15 |
Hi Toby,
Great news!!! Please, let us know if you have any other issue or any feedback that you would like to share. Regards, IHFOAM Team
#16 |
Luís Tiago Ferreira Fernandes
Hello everyone. I've managed to install the gui and started to create a new case.
When I run snappyHexMesh I get a error saying " keyword castellatedMeshControls is undefined in dictionary" Can anyone help me ? |
#17 | |
Hi Tiago
Have you tried any of the tutorials that are included in the folder: tutorials/multiphase/interFoam/laminar/? Regards, IHFOAM Team.
#18 |
I'm using openfoam-v1706 for the ihfoam gui.
I've tried one of the tutorials but if I'm not mistaken, none of them uses snappyhexmesh. |
#19 | |
Hi Tiago,
It looks to me as there must be a problem when you define your .stl files (maybe the names or a missing bracket). Can you post your snappyHexMeshDict file here? Regards, IHFOAM Team.
#20 | |
Luís |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
