March 12, 2020, 08:41 |
#61 |
Callum Guy
Rep Power: 6 |
Hi Santiago,
Thank you very much for the reply I appreciate it! I managed to get some success using OF-v1806 (discarding the GUI), I didn't manage to complete either of the first tutorials on the IHFoam website however, due to errors. Could I ask with IHFoam now intergrated into official OpenFOAM releases, is the interFoam solver the same as the ihFoam solver? Is there any need to comile the IHFoam source code? Cheers Callum |
April 9, 2020, 05:01 |
#62 | |
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
Rep Power: 9 |
Hi CallumG,
IHFOAM will be added in the future to the official release, meanwhile you must compile it as it is explained here: https://ihfoam.ihcantabria.com/model/gui/ Regards, IHFOAM Team.
http://ihfoam.ihcantabria.com/ |
July 2, 2020, 18:25 |
#63 |
Tomas Cuevas
Rep Power: 7 |
Hi IHFoam Team,
I'm quite new with openfoam. I'm trying to run the tutorials but I'm having problems with blockMesh. I'm getting this error message: (I have ubuntu 20.04) ERROR!! /usr/bin/sh: 136: .: Can't open /openfoam7/etc/config.sh/functions I changed the permissions of the complete openfoam installation folder to be read, write and execute, but the problem remains. My OF installation is working perfectly outside the IHFoam GUI. It is possible to run IHFoam with OF7?? (downloaded from https://openfoam.org/). Thanks! Tomás |
July 15, 2020, 04:20 |
#64 | |
Rep Power: 9 |
Hi Tomás,
Best Regards, IHFOAM Team
October 27, 2020, 10:15 |
IHFoam compile error and GUI installation
#65 |
Hattab Abdelhak
Rep Power: 6 |
i'm begginer in OpenFoam and want to learn to use it. i'm not sure if this is the right place to expose my problem (correcte me if i'm wrong), i donloaded OPENFOAM v1812 and succefully compile it (not got error) but when i try to compile IHFoam using Allmake script gor error (see attached screenshot), what's wrong ?
secondly , i want to use IHFoam GUI v2_3, i dwnloaded it but not have any idea how to install it, i tried to excute it directly but got error, any wone can help me to resolve this problems? thank's |
November 5, 2020, 07:32 |
#66 | ||
Rep Power: 9 |
Hi
Download it from here: https://ihfoam.ihcantabria.com/source-code/ Quote:
https://ihfoam.ihcantabria.com/model/gui/ And use the tutorials to start learning how to use it: https://ihfoam.ihcantabria.com/source-code/tutorials/ Best Regards, IHFOAM Team
November 11, 2020, 05:38 |
#67 |
philip lu
Rep Power: 7 |
Hello, IHFOAM Team,
in your tutorial "Breaking solitary waves on a mild slope (2D)", the "U" in "outlet" of "0.org" shall be updated to outlet { type noSlip; } from outlet { type waveVelocity; value uniform (0 0 0); } why or is it correct? yes, the outlet in this case is on bank top, i.e. is open/air (instead of inside water), so the "type waveVelocity;" of U needs update, but why "noSlip"? thanks, best @Doum2 "... can you ... show me how you compile IHFoam ? ....": Compiling "GUI": I've no experience, assume, following the manual, it can be done Comiling "command version": there's also manual, according to which compiling can be done by means online or offline Last edited by philiplu; November 12, 2020 at 07:40. |
November 12, 2020, 06:13 |
#68 | |
Hattab Abdelhak
Rep Power: 6 |
i would appriciate |
December 15, 2020, 06:19 |
IHFoam GUI error
#69 |
Hattab Abdelhak
Rep Power: 6 |
I'm sorry once again for my questions but this time I have a new error which appears after I run the set patches names command as you can see on the screenshots
I have checked the project folder and the blockMeshDict file exists with the settings I entered on IHFoam GUI. any Idea? |
December 17, 2020, 13:39 |
Problem to use IHFOAM GUI
#70 |
Luiz Ferreira
Rep Power: 6 |
Hi everyone,
I am running OpenFOAM-v1812, wsl2 Ubuntu 18.04 and I am trying to install IHFOAM GUI. Unfortunately there has been some errors in the program. - 1st: When I try to create a new Project, everytime appears the following message "ERRROR!! Couldn't initialize the OpenGL context." and "ERROR!! The project has not been created" Error.jpg Error2.jpg - 2nd: When I try to click at "Load Tutorials" nothing happens. Load_Tutorials.jpg After I leave the program the following message appears in the terminal: "QMetaObject::connectSlotsByName: No matching signal for on_btnOpenFoamPreferences_clicked() QMetaObject::connectSlotsByName: No matching signal for on_btnParaviewPreferences_clicked() QMetaObject::connectSlotsByName: No matching signal for on_menuLoad_Recent_Project_Item_triggered(QAction* ) QMetaObject::connectSlotsByName: No matching signal for on_btnOk_NamePatches_clicked() QMetaObject::connectSlotsByName: No matching signal for on_btnCancel_NamePatches_clicked() QMetaObject::connectSlotsByName: No matching signal for on_btnStatusBar_clicked() libGL error: No matching fbConfigs or visuals found libGL error: failed to load driver: swrast" |
February 26, 2021, 12:55 |
OpenFOAM v1812 + IHFoam 2.3
#71 |
Milad
Rep Power: 6 |
Hello Guys,
I would be appreciated if you could answer my question. I installed IHFoam on ubuntu 20.04 on virtual box. and compiled OpenFOAM 1812. when I want to do blockMesh I got this error. |
April 9, 2021, 06:35 |
"Export icon" kudos
#72 | |
Tomas
Rep Power: 7 |
I agree that adding this "export icon" to export data as csv would be awesome and really help those that don't usually work with Linux and Python. Otherwise, the tool is becoming great! Do you have an ETA on when the "Export Case" button will be available? Thanks! |
April 9, 2021, 08:12 |
Probes data to csv
#73 | |
Tomas
Rep Power: 7 |
ms.hasempour I found a Python script that exports the line probes data to a csv file, it is easy to use and seems to work well: https://github.com/NKrvavica/LineProbes I also recommend making it executable and adding to the $PATH if you want to use it often, as suggested by him. Let me know if you need help using it! Cheers |
June 21, 2021, 01:09 |
#74 |
Dave Unwin
Rep Power: 8 |
I'm trying to use the GUI with OpenFoam-v2012 but I'm also getting the "The OpenFoam path was not found..." error.
OpenFoam itself is working fine, and I have specified the correct path in the GUI (/opt/OpenFOAM/OpenFOAM-v2012) Can anyone help out where I'm going wrong? Thank you! Cheers Dave Last edited by unners; June 22, 2021 at 06:59. |
July 20, 2021, 05:42 |
Installation IHFOAM
#75 |
Rosangela
Rep Power: 5 |
Hello everyone!
I want to use IHFOAM for modeling solitary waves impacting two cylinders. Unfortunately, I am having problems installing the tool. On the Ubuntu Virtual machine I have already installed OpenFOAM version 8. I also downloaded IHFOAM software and, after receiving the email from The IHFOAM Team, I cloned the repository with the reference manual, additional materials and tutorials on my computer. I can't update the software with "git checkout" and "git pull" and also from the GUI I can't even load a tutorial. I was wondering if you would be kind enough to help me solve this problem. Thank you in advance! |
July 20, 2021, 09:44 |
#76 | |
Dave Unwin
Rep Power: 8 |
July 22, 2021, 08:12 |
#77 |
Dave Unwin
Rep Power: 8 |
Further to my earlier post, I've reinstalled OpenFoam in the User directory, but still getting the "The OpenFoam path was not found... error". In the GUI, it doesn't seem to remember the locations for OpenFoam or Paraview?
August 23, 2021, 16:25 |
Help with IHFoam GUI Installation
#78 |
Scott Hicks
Rep Power: 5 |
I have installed OpenFoamv1906 (and also have tried with OpenFoamv2012 and I get the same issue). I have downloaded the IHFoam installer (IHFoamV2_3). When I run the installer, I get the following error:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-shicks33' qt.qpa.screen: QXcbConnection: Could not connect to display Could not connect to any X display. Any suggestions as to what could be causing this and how to resolve it? Thanks! |
October 11, 2021, 12:32 |
#79 | |
Rep Power: 9 |
Hi Dave,
Best, IHFOAM Team
October 11, 2021, 12:35 |
#80 |
Rep Power: 9 |
Hi Rosangela,
IHFOAM-GUI just works under the ESI's official release. Please, download it from here: https://www.openfoam.com/news/main-news/openfoam-v2106 Best, IHFOAM Team
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 8, 2019 00:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 05:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 04:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 12:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
