[IHFOAM] The IHFOAM-GUI Thread
Like Tree6Likes
Old   October 22, 2019, 06:50
OVERSEAS
asra29 is on a distinguished road
Thank you IHFOAM team .. from the link given here is allowing to download v1. Not v2 .
regards,
asra
asra29 is offline   Reply With Quote
Old   October 22, 2019, 07:09
IHFOAM Team's Avatar
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
IHFOAM Team is on a distinguished road
Hi Asra29
Can you check again??
Regards,
IHFOAM Team
http://ihfoam.ihcantabria.com/
IHFOAM Team is offline   Reply With Quote
Old   December 13, 2019, 08:34
HI all,
We have uploaded the latest version of IHFOAM-GUI with new functionalities:
- statict and dynamic wave generation.
- fully compatible with versions v1812 and v1906.
- improvement in the domain visor.
As usual, it can be downloaded from:
(https://ihfoam.ihcantabria.com/model/gui/):
We will be very happy to hear from the users any feedback, pros and cons, in order to improve the capabilities of the graphical interface.
Regards,
IHFOAM Team
Old   December 23, 2019, 05:31
Default Automatically create dictionaries
  #44
Tomas
habitatguy is on a distinguished road
Hi!
First, congratulations on the new GUI, it is very good.
However, I noticed that the GUI crashes every time I save a panel that modifies a dictionary that does not exist on the case folder yet. I solve this by manually copying a dictionary file from another case, but it would be great if the GUI automatically created dictionaries when you save a panel that writes on that non-existing dictionary.
Thanks!
Regards,
Tomás
habitatguy is offline   Reply With Quote
Old   December 26, 2019, 22:51
Exclamation Error: did not locate installation path for OpenFOAM-v1906
  #45
Chu
Chu Yuefeng
Chu is on a distinguished road
The IHFOAM looks great
But my problem is, when I click on the blockmesh, this prompt pops up,"Error: did not locate installation path for OpenFOAM-v1906 No directory: /home/cyf/OpenFOAM/OpenFOAM-v1906
/bin/sh: 1: blockMesh: not found"
I use the Ubuntu subsystem of Windows10, version 18.04.I'm using pre-compiled Openfoam v1906.I've entered the correct path. What should I do?
Thanks!
Chu is offline   Reply With Quote
Old   December 27, 2019, 09:47
Lightbulb I finally solved the problem.
  #46
Chu
Chu Yuefeng
According to the dialog box, OpenFOAM must be installed in the user folder.
Old   January 6, 2020, 08:17
Default Install Error
  #47
Masoumeh
ms.hashempour is on a distinguished road
I have ubuntu 18.04 and openFOAM 1812. When I want to install the ihFOAM GUI, the install app doesnt work...I have this error:
"Could not display "InstallerIHFoam V2-2-121219".
would u plz help me:
It should be noted that I used the link in this page:
ms.hashempour is offline   Reply With Quote
Old   January 10, 2020, 03:59
Hi Massoumeh,
Originally Posted by ms.hashempour View Post
I have this error:
It is very difficult to solve this issue with just this info, but please, can you check if what you have diownloaded has the right permissiones to be executed?
Try: sudo chmod +x InstallerIHFoam
Regards,
IHFOAM Team
Old   January 10, 2020, 04:03
Hi Chu,
Yes, IHFOAM GUI it is "just" a graphical user interface, a front-end, that will use all the potential of OpenFOAM once it is installed.
Therefore, you must download and compile IHFOAM in order to use IHFOAM GUI.
Regards,
IHFOAM Team
Old   January 10, 2020, 04:07
Hi Tomas,
Originally Posted by habitatguy View Post
Hi!
Great!! Thank you very much for the feedback, our idea is to solve all the issues to achieve a complete robust tool.
Please, can you give us more information about which dictionary was not working proiperly?
Regards,
IHFOAM Team
Old   January 23, 2020, 10:10
Santiago Delgado Torres
Sdelgado is on a distinguished road
Hello IHFOAM Team,
Regards,
IHFOAM Team
I am pretty new to OpenFOAM and Ubuntu so the question may seem trivial but I don´t understand what you mean.
I am currently working on a Ubuntu VirtualBox, and I installed the IHFOAM GUI and OpenFOAM with paraview as it is explained in this link:
https://openfoam.org/download/7-ubuntu/
but when I try to use the blockMesh button inside the GUI this error appears:
/bin/sh: 136: .: Can't open /openfoam7/etc/config.sh/functions
Is the error associated with not having IHFOAM downloaded and compiled? If so, how do I do that?
Also, if I use the blockMesh command in a Terminal it works just fine.
Thanks
Santiago
Sdelgado is offline   Reply With Quote
Old   January 27, 2020, 16:47
Default I think i solved the issue
  #52
Hello again,
I think I solved the issue by compiling OpenFOAM v1912 from source on the home directoryas Chu said. I did that by following the steps in this links:
https://www.openfoam.com/download/install-source.php
https://www.openfoam.com/code/build-guide.php
The problem I now have is that i cannot find the ParaView bin, if someone knows where it is it will be great.
Thanks
Santiago
Old   February 18, 2020, 11:41
Hi Santiago
IHFOAM GUI can just work with ESI's version.
You must install this version:
Best Regards,
IHFOAM Team
Old   February 18, 2020, 11:44
Hi again Santiago,
You have to download Paraview to any folder in your laptop:
https://www.paraview.org/download/
Regards,
IHFOAM Team
Old   March 3, 2020, 04:35
Default Export
  #55
Masoumeh
Would you plz add "export icon" for exporting the free surface elevation data to excel or other programs? It is really necessary.
Also, adding sediment transport majola can enhance the GUI and Meets all needs.
Thanks for your attention and providing this Amazing tool
habitatguy likes this.
Old   March 3, 2020, 06:03
Masoumeh
Hello again!
Would you plz tell me how I can see the weeds in "waveMangroveInteraction" tutorial when I load it in GUI?
Old   March 9, 2020, 11:36
Hi ms.hashempour,
We are working in improving the post-processing tools of the GUI!
We hope to find some time and founding to add all this new improvements in the next release.
Regards,
IHFOAM Team.
ms.hashempour likes this.
Old   March 9, 2020, 11:41
Hi again ms.hashempour,
You can not add weeds yet.
We have already created this functionality but as you can see when using the GUI the activate button is disabled. It will be released soon.
Regards,
IHFOAM Team.
Old   March 11, 2020, 12:12
Default New User Issues
  #59
Callum Guy
CallumG is on a distinguished road
I run OpenFOAM-2.4.0 on Ubuntu 18.04 as I use bespoke libraries written for this particular version. After compiling IHFoam and the GUI I attempt to run the first tutorial from here:
https://ihfoam.ihcantabria.com/wp-co...M_Course_1.pdf
I have 2 issues:
1) I don't know if the tutorial is out of date but it doesnt allow me to allocate patch names: "sides". So if I set all the patch attributes as in the tutorial, selecting the same attributes for patches "front" and "back" as the tutorial uses for "sides", I get an error when I try to run:
ERROR!!
--> FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
    patch type empty and patchField type fixedFluxPressure
file: /home/callum/OpenFOAM/callum-2.4.0/run/Tutorial1_IHFoam/0/p_rgh.boundaryField.front from line 32 to line 33.
    From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
    in file /home/callum/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 172.
FOAM exiting
2) If I go into the case files manually and edit the /constant/polyMesh/boundary file such that both front and back are type "patch" I get error:
Unknown patchField type waveVelocity for patch type patch
Valid patchField types are :
77
IH_3D_3DAbsorption_InletVelocityV2
IH_Waves_InletVelocityV2
SRFFreestreamVelocity
SRFVelocity
activeBaffleVelocity
activePressureForceBaffleVelocity
advective
atmBoundaryLayerInletVelocity
calculated
codedFixedValue
codedMixed
cyclic
cyclicACMI
cyclicAMI
cyclicSlip
cylindricalInletVelocity
directionMixed
empty
externalCoupled
fixedGradient
fixedInternalValue
fixedJump
fixedJumpAMI
fixedMean
fixedNormalInletOutletVelocity
fixedNormalSlip
fixedValue
flowRateInletVelocity
fluxCorrectedVelocity
freestream
inletOutlet
interstitialInletVelocity
kqRWallFunction
mapped
mappedField
mappedFixedInternalValue
mappedFixedPushedInternalValue
mappedFlowRate
mappedVelocityFlux
mixed
movingWallVelocity
nonuniformTransformCyclic
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
outletPhaseMeanVelocity
partialSlip
pressureDirectedInletOutletVelocity
pressureDirectedInletVelocity
pressureInletOutletParSlipVelocity
pressureInletOutletVelocity
pressureInletUniformVelocity
pressureInletVelocity
pressureNormalInletOutletVelocity
processor
processorCyclic
rotatingPressureInletOutletVelocity
rotatingWallVelocity
sliced
slip
supersonicFreestream
surfaceNormalFixedValue
swirlFlowRateInletVelocity
symmetry
symmetryPlane
timeVaryingMappedFixedValue
translatingWallVelocity
turbulentInlet
uniformFixedGradient
uniformFixedValue
uniformInletOutlet
uniformJump
uniformJumpAMI
variableHeightFlowRateInletVelocity
waveTransmissive
wedge
zeroGradient
I have tried installing OF-v1806 and in that case the GUI can't even find the blockMesh command.
Any help appreciated.
Cheers
Callum
CallumG is offline   Reply With Quote
Old   March 11, 2020, 15:13
Hi Callum
For the first issue what I usually do is change the names of the Patches in the blockmeshDict before running blockMesh
In my personal experience the second issue is caused because OF-2.4.0 doesn't have the waveVelocity and other tools that IHFOAM requires.
You should install another version of OpenFOAM. I installed v1912 following these links (if I remember correctly) and got it running with no problems
I hope it works ,
Also, if the GUI is not finding the blockMesh command it is probably because OpenFOAM is installed in another directory (like /opt) than the GUI (e.g. /home)
Santiago
Divergence detected in AMG solver: k when udf loaded google9002 Fluent UDF and Scheme Programming 3 November 8, 2019 00:34
udf problem jane Fluent UDF and Scheme Programming 37 February 20, 2018 05:17
UDF velocity profile willroca Fluent UDF and Scheme Programming 2 January 10, 2016 04:13
Error messages atg enGrid 7 August 30, 2013 12:16
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
