[PyFoam] Using pyFoamPlotWatcher.py To Plot Residuals |
#21 |
Rep Power: 5 ![]() |
Many thanks Bernhard !
I was unable to remove all these files but uninstalling/resinstalling pyFoam was enough to take this step. Now I have a new problem which seems about gnuplot: Code:
$ pyFoamPlotRunner.py simpleFoam PyFoam WARNING on line 37 of file /usr/local/lib/python3.8/dist-packages/PyFoam-2020.5-py3.8.egg/PyFoam/Infrastructure/ServerBase.py : No certficate file (...) no SSL-connection (...) gnuplot: unable to open display ':0' gnuplot: X11 aborted. Terminal type is 'wxt' do you have any idea about what could be wrong ? |
#22 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 ![]() ![]() |
X11 is a server-client protocol. The program is the client. It needs a program that does the actual drawing: the X11-server (on Unix this is running on every machine that has a GUI because it draws the GUI). Seems that such a program is not running on your machine Don't know what is the recommended X-server on windows nowadays
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
#23 | |
Petros Ampatzidis
Rep Power: 7 ![]() |
Best, Petros Last edited by petros; January 26, 2021 at 18:53. Reason: typo |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
How to plot residuals vs iterations using pyFoam... | ata313ata | Visualization & Post-Processing | 1 | February 6, 2018 04:34 |
Plot the residuals over all the domain | Douglas | OpenFOAM Post-Processing | 0 | June 27, 2017 16:01 |
plot residuals | pigna | OpenFOAM Running, Solving & CFD | 2 | December 19, 2014 02:32 |
How to plot residuals of all iterations in Fluent | FJSJ | FLUENT | 4 | September 20, 2013 09:47 |
