Hi all,
currently I'm using cfMesh as meshing tool. I found out the Code:
improveMeshQuality Code:
Default number of loops is 10 Default number of iterations is 50 Default number of surface iterations is 2 Using default quality threshold 0.1 No constraints applied on the smoothing procedure Now I would like to ask if it is possibile to set it up to work on specific errors that arise with the Code:
checkMesh e.g. If checkMesh shows a huge non-ortogonality value (> 80) I would like to make Code:
improveMeshQuality This is a checkMesh after a single run with cartesianMesh Code:
Overall domain bounding box (-4.43393e-012 0.3235 -0.225969) (0.25 1.012 0.318) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-9.98583e-015 2.23961e-015 9.44861e-016) OK. Max cell openness = 8.63145e-016 OK. Max aspect ratio = 139.552 OK. Minimum face area = 2.08953e-009. Maximum face area = 2.05036e-005. Face area magnitudes OK. Min volume = 4.11405e-013. Max volume = 5.75174e-008. Total volume = 0.0601205. Cell volumes OK. Mesh non-orthogonality Max: 88.6164 average: 6.16081 *Number of severely non-orthogonal (> 70 degrees) faces: 407. Non-orthogonality check OK. <<Writing 407 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Average skewness 0.0461554 ***Max skewness = 5.73023, 266 highly skew faces detected which may impair the quality of the results <<Writing 266 skew faces to set skewFaces Coupled point location match (average 0) OK. Code:
Checking geometry... Overall domain bounding box (-4.43393e-012 0.3235 -0.225969) (0.25 1.012 0.318) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.03912e-014 2.23071e-015 9.15085e-016) OK. Max cell openness = 1.44747e-015 OK. Max aspect ratio = 55.296 OK. Minimum face area = 1.8092e-009. Maximum face area = 2.05036e-005. Face area magnitudes OK. Min volume = 7.42452e-014. Max volume = 5.12649e-008. Total volume = 0.0601206. Cell volumes OK. Mesh non-orthogonality Max: 86.0757 average: 8.91875 *Number of severely non-orthogonal (> 70 degrees) faces: 9567. Non-orthogonality check OK. <<Writing 9567 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Average skewness 0.0406472 ***Max skewness = 4.91016, 2 highly skew faces detected which may impair the quality of the results <<Writing 2 skew faces to set skewFaces Coupled point location match (average 0) OK. Regards. |
