May 3, 2017, 10:00 |
Inlet Boundary with groovyBC
Rep Power: 9 |
Hello everyone,
I'm currently working on a spillway simulation where I want to set my inlet boundary as a constant flow height (h=3m). I want the flow to be pressure-driven by a hydrostatic pressure distribution at the named flow height. I chose the interFoam solver. I divided the inlet patch into a inletWater (alpha=1) and inletAir (alpha=0). Now, I'd like to set up a hydrostatic pressure for the inletWater patch: inletWater { type groovyBC; valueExpresion "9810.*(3-pos().z)+100000"; fractionExpression "1"; rho rho; psi none; gamma 1; p0 uniform 100000; value uniform 100000; } Checking this setup (and many alternatives) does not provide a hydrostatic pressure distribution, but a single value for the whole patch (=100000). I also prescribed a water phase with a pressure distribution for the internal field using funkySetFields which works successfully. expressions ( pressureWater { field p_rgh; //field to initialise expression "9810.*(2-pos().z)+100000"; condition "(pos().z<2) && (pos().z>=0)"; //ranging from 2 meter to 0 meter keepPatches 1; } ); How can I setup my inlet to have a constant hydrostatic pressure for a given flow height? I'm probably missing something fundamental. Since I'm googling since weeks now, I'm getting frustrated. Kind regards, fmerk |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
