[swak4Foam] Extracting data using swak4foam
Old   April 19, 2017, 04:42
Default Extracting data using swak4foam
Manu Chakkingal
manuc is on a distinguished road
Hello All
I would like to know if its possible using swak4foam to extract a small portion of data.
For example: I have a large cubical volume. I would like to extract a small portion of it , say a small cube of data from the center.
Is it possible to do it with swak4foam. My aim is to use the extracted data to draw a probability distribution function.
( I found that there is a utility in paraview to extract the data what I am looking for.
Extract Subset: Extracts a subset of a grid by defining either a volume of interest or a sampling rate
I would like to maintain the same interpolating scheme as used in the solver, which I believe cannot be ensured when using paraview )
Regards
Manu
manuc is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Extracting the matrix data from an fvVectorMatrix stevemoore1981 OpenFOAM 7 October 20, 2020 08:50
[General] problem with extracting data from paraview a.hajisharifi ParaView 5 April 29, 2016 12:38
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Extracting Stream Function from nodal u,v data Abhijit Tilak Main CFD Forum 5 March 8, 2004 17:13
