[cfMesh] how to install on bash for windows 10
Old   April 18, 2017, 19:47
Default how to install on bash for windows 10
M. C.
student666 is on a distinguished road
according to these release notes, I succefully downloaded and installed OF on bash into windows 10.
https://openfoam.org/download/windows-10/
Is there a way to install cfMesh as well as a similar way to above link?
If I run Allwmake script I have following errors:
wmake libso meshLibrary
/opt/openfoam-dev/wmake/wmake: row 405: make: command not found
/opt/openfoam-dev/wmake/wmake: row 408: make: command not found
/opt/openfoam-dev/wmake/wmake: row 434: make: command not found
/opt/openfoam-dev/wmake/wmake: row 465: exec: make: command not found
/opt/openfoam-dev/wmake/wmake: row 316: make: comando non trovato
wmake utilities
but If I list the opt directory I can see that there's the wmake folder:
winuntu@DESKTOP-PKLACF4:/opt/openfoam-dev$ tree -L 1
├── Allwmake
├── applications
├── bin
├── build-stamp
├── COPYING
├── doc
├── etc
├── platforms
├── README.org
├── README_scotch
├── src
├── tutorials
└── wmake
and
winuntu@DESKTOP-PKLACF4:/opt/openfoam-dev/wmake$ tree -L 1
├── makefiles
├── platforms
├── rules
├── scripts
├── src
├── wclean
├── wcleanLnIncludeAll
├── wcleanPlatform
├── wdep
├── wmake
├── wmakeCheckPwd
├── wmakeCollect
├── wmakeFilesAndOptions
├── wmakeLnInclude
├── wmakeLnIncludeAll
├── wmakePrintBuild
├── wmakeScheduler
├── wmakeSchedulerUptime
├── wrmdep
└── wrmo
Please, can someone help me?
Regards.
student666 is offline   Reply With Quote
Old   April 19, 2017, 01:30
me3840 is on a distinguished road
I think the problem is that you're missing the binary or alias for make. You can find out easily by running:
which make
at the terminal. If it returns an error, then you need to install make. No idea how to do this on Winbash. Does it have apt? You should be able to install it from there.
If make is installed but the command 'make' is not an alias to its binary you may have to create that alias.
Obligatory "everything is better on Linux, just use Linux" comment.
me3840 is offline   Reply With Quote
Old   April 19, 2017, 07:46
M. C.
Hi thanks for the hint. I agree with you about linux, but it's a company workstation and it must have Windows as main OS. I'll check your suggestion.
Regards
Sent from my ASUS_X008D using CFD Online Forum mobile app
Old   December 23, 2019, 07:00
giovanni
gian93 is on a distinguished road
hi I resume this post because I have a similar problem. Where I can found the complete instruction to run cfMesh on wsl?
thanks
gian93 is offline   Reply With Quote
Old   December 27, 2019, 17:05
Retired Super Moderator
Bruno Santos
Quick answer: When compiling custom code to work with OpenFOAM, you need to install the packages needed for development as well. For example, the packages needed for OpenFOAM from the OpenFOAM Foundation are listed here: https://openfoam.org/download/source...r-compilation/
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[OpenFOAM.com] Installation of OpenFOAM 1.7.1 on Ubuntu 16.04 MM_Khan OpenFOAM Installation 11 September 3, 2017 10:22
[OpenFOAM.org] Can't find files when install OF2.1.1 on Mac hewei OpenFOAM Installation 10 June 3, 2016 07:50
Unable to install OpenFOAM 1.6-ext Maimouna OpenFOAM Installation 23 May 8, 2014 06:47
install OF2.1.1@Fedora17, error--> bash: module: command not found TaPantaRei OpenFOAM Installation 2 September 16, 2012 12:13
