[swak4Foam] and snappyHexMesh gives erratic mesh result |
Jorge Rivas Ordenes
Rep Power: 9 ![]() |
Hello everyone! Thanks in advance for the time you might take when reading this thread.
I am currently working on a Large-Eddy Simulation (LES) of the Atmospheric Boundary Layer (ABL) flow in a 1250m x 800m x 800m computer domain. I will attempt to recreate a previous simulation (available for the public), to ensure that the model i have created is appropriate (all this for academic purposes). The work i am currently working on, involves recreating two rather complicated topics, which till to this point i thought i had managed to circumvent all issues arising from them:
[IMG]file:///home/cokerivas/Desktop/forumPictures/blocks.png[/IMG] [IMG]file:///home/cokerivas/Desktop/forumPictures/blocks.png[/IMG]To achieve the first point (power-law profile) i use swak4foam (specifically funkySetFields) to create such a profile. To achieve the second point (the three blocks) i wrote the proper snappyHexMeshDict. Following, in both cases, OF tutorials and the invaluable information share through this forum, thanks again to the contributors. And it had all went splendid, or so i thought. To test the simulation, i run it using the PISO solver provide in OF, for scarcely 3 physical seconds with a time step of 0.1 seconds. At this point of the thread i must specify that both snappyHexMesh and the PISO solver, were run in parallel using 4 processors (snappyHexMesh used a ptscotch decomposition method, while decomposePar used hierical). The test-simulation conclude with no issues or fatal OF error messages. The problem arose when visualizing the velocity field in paraview. I notices there were manny "velocity hot spots" in the domain, and later realize that the hot spots were there for fields nut, nuTilda and k. As the image "hotSpots_parallelRunning" illustrates: hotSpots_parallelRunning.png In a further analysis i could conclude that the "hot spots" coincided with the union between processors, as you can see comparing the previous image, with image "hotSpots_minusProcessor4". hotSpots_minusProcessor4.png Furthermore, when para-viewing the lower wall (set to fixed value of 0 in the velocity boundary field) i notice a "crack" in the interface between processor 0 and processor 1, as shown in image "lowerWall_Crack" (in this image you can also visualize the position of the three blocks): lowerWall_Crack.png So the question are:
#!/bin/sh cd ${0%/*} || exit 1 # Run from this directory # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions # Make dummy 0 directory mkdir 0 runApplication blockMesh cp system/decomposeParDict.hierarchical system/decomposeParDict runApplication decomposePar cp system/decomposeParDict.ptscotch system/decomposeParDict runParallel snappyHexMesh -overwrite -parallel find . -type f -iname "*level*" -exec rm {} \; ls -d processor* | xargs -I {} rm -rf ./{}/0 ls -d processor* | xargs -I {} cp -r 0.orig ./{}/0 $1 runApplication funkySetFields -case processor0 -time 0 mv log.funkySetFields log.funkySetFields1 runApplication funkySetFields -case processor1 -time 0 mv log.funkySetFields log.funkySetFields2 runApplication funkySetFields -case processor2 -time 0 mv log.funkySetFields log.funkySetFields3 runApplication funkySetFields -case processor3 -time 0 mv log.funkySetFields log.funkySetFields4 runParallel pisoFoam runApplication reconstructParMesh -constant -mergeTol 1e-6 runApplication reconstructPar #------------------------------------------------------------------------------# Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object funkySetFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // theVariables ( "nu = 1.5e-05;" "u_star = 0.5;" "B = 5.2;" "kappa = 0.41;" "delta_nu = 3.33e+04;" "Ux = 0.0;" "Uy = 0.0;" ); expressions ( velocityField { field U; create false; expression "vector((0.5)*((1/0.41)*log((pos().z)/0.00003)+5.2),0,0)"; keepPatches true; variables $theVariables; } ); Thank you very much for any contributions you might do. Sorry if the problem is not well explain or for the lack of documentation. It is my first attempt in this forum and english is not my first language, hopefully i will improve with time. Thanks to people creating features such as swak4foam and openFoam itself.
Rep Power: 16 ![]() |
Have you tried the default boundary condition for ABL in OF? atmBoundaryLayerInletVelocity? Is that not suitable for your simulation? Also, how coarse or fine is your mesh? Out of curiosity, why do you use separate decomposition types for decomposePar and snappy? Can you not run funkySetFields in parallel instead of running it on every processor? Cheers, Antimony |
Jorge Rivas Ordenes
Hello Antimony!
I tried the ABL default boundary conditions provided by OF, but as you mentioned, they do not suit to my simulation; mostly because i need a cyclic inlet/outlet condition, but for many others reason as well. The mesh is mainly compose by 10m x 10m x 10m cubic elements, with a refinement in the height-direction (z) close to the lowerWall (ground), where the size of the cubic elements is approximately 10m x 10 m x 3 m (x, y, z). I use two decomposition methods (one for decompose par and a second for snappy) because the All run script is base on a the LES motorBike tutorial, which uses two different decomposition methods as well. I have already try using only one decomposition method (hierical) for both decompose and snappy, but it didn't yield any good results (they were far more erratic). It haven't occur to me to run funkySetFields in parallel, i will have to check that out. Thank you for that. Any thoughts? Regards, Jorge |
#4 | |
Jorge Rivas Ordenes
Does anyone has a clue (intuition or hunch) from where does the problem rises? Thanks everyone! |
mesh error, parallel snappyhexmesh, snappyhexmesh, swak4foam |
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh | JD_Welch | OpenFOAM Meshing & Mesh Conversion | 10 | July 5, 2023 11:50 |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 15:15 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
