[swak4Foam] averaging in spanwise direction of a patch
Old   April 6, 2017, 07:25
Default averaging in spanwise direction of a patch
Felix Kraft
kenny13 is on a distinguished road
Hi all,
I'm trying to get an average of the velocity x-component on the outlet patch along z-direction using simple function objects.
Waht I figured out yet was to get the U-values of the outlet patch by using Uout{outlet}=U, which allows me to get only an average over the entire patch. This is not exactly what I need... I am trying to average Uout.x along the z-coordinate for all pos().y of the outlet patch.
Hope the explanation isn't to confusing probabliy the picture might provide clarity. The dashed line shows the averaging direction.
Hope someone can help me on this tricky problem and thank you in advance
greetings,
Felix
kenny13 is offline   Reply With Quote
Old   October 3, 2017, 11:07
Bhanu
mugabe2204 is on a distinguished road
Hi Kenny,
Were you able to resolve this ? It would be of great help if you can share the solution for this issue.
Thanks.
mugabe2204 is offline   Reply With Quote
averaging in z-direction, averging along a line, swak4foam
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[mesh manipulation] Using createPatch in place of couplePatches sripplinger OpenFOAM Meshing & Mesh Conversion 8 November 13, 2009 08:14
Averaging field over a spatial direction fs82 OpenFOAM 10 August 12, 2009 11:44
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
