[cfMesh] Symmetry patch issue in cfMesh from stl file
Old   March 25, 2017, 07:47
Default Symmetry patch issue in cfMesh from stl file
badoumba
badoumba is on a distinguished road
Good morning everyone,
I am trying to set an external aerodynamic case with a symmetry plane in cfMesh. My 3D file is a stl, so there is only the patch name, no type (wall, patch, symmetry, slip...).
This is different from the racing car case in cfMesh website, although there is no symmetry plane declared in the fms file.
Should I simply use the renameBoundary dictionnary to change the type of my symmetry plane from whatever to symmetry?
boundaryLayers{
 symmetryPlaneLayerTopology 1;
 generateLayersAtSymmetryPlanes 0;
renameBoundary
 newPatchNames
  sym
   type symmetry
Thanks for any tip !
badoumba is offline   Reply With Quote
Old   May 28, 2018, 09:47
Dr. Peyman Davvalo Khongar
peyman.davvalo.khongar is on a distinguished road
Moi,
I suggest you to do this, its much easier.
If you have an stl file (for example geo.stl) with boundaries, simply run the following command:
surfaceFeatureEdges -angle n geo.stl geo.fms
where n can be any feature angle that you want. (you can use for example 60)
Then cfMesh creates you the fms format of your geometry. Open the fms file and you can put the types that you have for your faces in the fms file. As an example here i have a face called banana and its type wall:
1(
banana
wall)
965
(0.0317752 0.00886576 0.0240078)
(0.0146394 0.027969 0.0258469)
(0.0257587 0.0212725 -0.0234224)
and I change the wall type to symmetry
1(
banana
symmetry)
965
You can even change the name of the face from for example banana to apple in the fms file. Then instead of stl in your meshDict use the fms file.
Its much easier to do this.
Moikka,
Peyman
peyman.davvalo.khongar is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
