[swak4Foam] Ellipsoid Particles using funkySetFields
Old   March 24, 2017, 13:31
Smile Ellipsoid Particles using funkySetFields
iain
beatsy is on a distinguished road
Hi all, I am new to OpenFOAM and i am trying to implement two ellipsoid shaped particles using funkySetFields to run using interFoam to simulate sintering. I have already successfully done this with two spheres but am unable to alter the formula correctly to change the shape.
I would like to make the centre of the two ellipsoids to be (0.01,0.0105,0.0105) and (0.011,0.0105,0.0105) respectively. With the dimensions in the x,y,z directions to be 0.0005,0.0008,0.0005 for both.
The two approaches i have already tried is:
funkySetFields -time 0 -keepPatches -field alpha.water -expression "pow(pos().x-((0.01)/0.0005),2) + pow(pos().y-((0.0105)/0.0008),2) + pow(pos().z-((0.0105)/0.0005),2)<1 || pow(pos().x-((0.011)/0.0005),2) + pow(pos().y-((0.0105)/0.0008),2) + pow(pos().z-((0.0105)/0.0005),2)<1 ? 1:0"
funkySetFields -time 0 -keepPatches -field alpha.water -expression "mag(pos()-vector(0.01/0.0005,0.0105/0.0008,0.0105/0.0005))<1 || mag(pos()-vector(0.011/0.0005,0.0105/0.0008,0.0105/0.0005))<1 ? 1:0"
If anyone could give any suggestions it would be much appreciated.
(For reference the equation of an ellipsoid is (x^2)/(a^2)+(y^2)/(b^2)+(z^2)/(c^2)=1)
beatsy is offline   Reply With Quote
how to determine the number of particles injected. welch FLUENT 2 January 18, 2024 05:08
dsmcFoam - micro-hole limiting the number of dsmc particles Araist OpenFOAM Running, Solving & CFD 0 June 25, 2015 07:50
Add lagrangian particles to OpenFoam solver luchen2408 OpenFOAM 0 June 2, 2015 04:10
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 22:33
particles model ati_ros61 FLOW-3D 3 December 6, 2009 17:03
