[swak4Foam] Problem with swak4Foam and OpenFOAM 2.3.1 |
February 25, 2017, 10:16 |
#1 | |
behzad Ghasemi
Rep Power: 13 |
I have same problem with installing SWAK 0.4.0 on OF-2.3.1. First i installed the SWAK and didn't noticed the error in end of the log file i attached here. Code:
Previously compiled for OpenFOAM 2.3.1 /home/behzad/OpenFOAM/behzad-2.3.1/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) Reading variables from 'swakConfiguration' swakConfiguration: line 13: [: : integer expression expected Checking swak4Foam-version and generating file abort: no repository found in '/home/behzad/OpenFOAM/behzad-2.3.1/swak4Foam' (.hg not found)! Swak version is 0.4.0 Bison is version 2.7.12-4996 Flex is version 2.5.39 (Minor version: 39) OpenFOAM-version: Major 2 Minor 3 Patch 1 (-1 == x / 1) Fork: openfoam No change to swak4FoamParsers/foamVersion4swak.H '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libgroovyBC.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libsimpleFunctionObjects.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libsimpleSearchableSurfaces.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libsimpleSwakFunctionObjects.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakTopoSources.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakSourceFields.so' is up to date. Compiling swakFvOptions '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakFvOptions.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libgroovyStandardBCs.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakPythonIntegration.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakChemistryModelFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakDynamicMeshFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakFvcSchemesFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakLagrangianCloudSourcesFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakLocalCalculationsFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakMeshQualityFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakMeshWaveFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakMRFFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakRadiationModelFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakRandomFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakSurfacesAndSetsFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakThermoTurbFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakTransportTurbFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakVelocityFunctionPlugin.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakCoalCloudAdaptor.so' is up to date. If you have your own function-plugins you can specify them using the SWAK_USER_PLUGINS environment variable and they would be compiled now. If you don't know what this means: don't bother. You propably don't need it '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libsimpleCloudFunctionObjects.so' is up to date. '/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib/libswakCloudFunctionObjects.so' is up to date. make[1]: `/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/funkyPythonPostproc' is up to date. g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam231/src/finiteVolume/lnInclude -I/opt/openfoam231/src/sampling/lnInclude -I/opt/openfoam231/src/meshTools/lnInclude -I../../Libraries/simpleFunctionObjects/lnInclude/ -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/opt/openfoam231/src/OpenFOAM/lnInclude -I/opt/openfoam231/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/fieldReport.o -L/opt/openfoam231/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lmeshTools -L/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/lib -lswak4FoamParsers -lOpenFOAM -ldl -lm -o /home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/fieldReport make[1]: `/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/calcNonUniformOffsetsForMapped' is up to date. make[1]: `/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/funkyDoCalc' is up to date. make[1]: `/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/funkySetBoundaryField' is up to date. make[1]: `/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/funkySetFields' is up to date. make[1]: `/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/funkySetLagrangianField' is up to date. make[1]: `/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/replayTransientBC' is up to date. Make/linux64GccDPOpt/fieldReport.o: In function `void reportValues<double>(Foam::word const&, Foam::fvMesh const&, Foam::CommonValueExpressionDriver&, Foam::string const&)': fieldReport.C:(.text._Z12reportValuesIdEvRKN4Foam4wordERKNS0_6fvMeshERNS0_27CommonValueExpressionDriverERKNS0_6stringE[_Z12reportValuesIdEvRKN4Foam4wordERKNS0_6fvMeshERNS0_27CommonValueExpressionDriverERKNS0_6stringE]+0x55): undefined reference to `Foam::CommonValueExpressionDriver::addAlias(Foam::word const&, Foam::word const&, bool)' Make/linux64GccDPOpt/fieldReport.o: In function `void reportValues<Foam::Vector<double> >(Foam::word const&, Foam::fvMesh const&, Foam::CommonValueExpressionDriver&, Foam::string const&)': fieldReport.C:(.text._Z12reportValuesIN4Foam6VectorIdEEEvRKNS0_4wordERKNS0_6fvMeshERNS0_27CommonValueExpressionDriverERKNS0_6stringE[_Z12reportValuesIN4Foam6VectorIdEEEvRKNS0_4wordERKNS0_6fvMeshERNS0_27CommonValueExpressionDriverERKNS0_6stringE]+0x55): undefined reference to `Foam::CommonValueExpressionDriver::addAlias(Foam::word const&, Foam::word const&, bool)' collect2: error: ld returned 1 exit status make[1]: *** [/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/fieldReport] Error 1 make: *** [fieldReport] Error 2 make[1]: `/home/behzad/OpenFOAM/behzad-2.3.1/platforms/linux64GccDPOpt/bin/funkyWarpMesh' is up to date. make: Target `application' not remade because of errors. If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/behzad/OpenFOAM/behzad-2.3.1/swak4Foam/Libraries (most people will be fine without setting that variable) Although your patch was for previous version, i applied it and nothing changed. Thanks in advance, |
March 2, 2017, 06:58 |
behzad Ghasemi
Rep Power: 13 |
Hi dear forumers,
I want to calculate falling droplet velocity using swak expresions. but when I want to decompose the domain or execute the solver i get error. my bison version is: Code:
bison (GNU Bison) 2.7.12-4996 My controlDict added codes for swak: Code:
libs ( "libOpenFOAM.so" // keeps paraFoam happy "libtwoPhaseProperties.so" "libtwoPhaseInterfaceProperties.so" "libinterfaceProperties.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" ); functions ( DropY { aliases { alphawater alpha.water; } ignore_unimplemented_simpleFunctionObject::movePoints true; type swakExpression; valueType internalField; verbose true; variables ( "Vol= sum (alphawater < 0.5 ? vol() : 0);" "VolY= sum (alphawater < 0.5 ? pos().y*vol() : 0);" ); expression "VolY/Vol"; accumulations ( min ); } createInterface { ignore_unimplemented_simpleFunctionObject::movePoints true; type createSampledSurface; outputControl timeStep; outputInterval 1; surfaceName interface; surface { type isoSurface; isoField alphawater; isoValue 0.5; interpolate true; } } height { ignore_unimplemented_simpleFunctionObject::movePoints true; type swakExpression; valueType surface; surfaceName interface; verbose true; expression "pos().y"; accumulations ( min max ); } surface { ignore_unimplemented_simpleFunctionObject::movePoints true; type swakExpression; valueType surface; surfaceName interface; verbose true; expression "area()"; accumulations ( sum ); } deviation { ignore_unimplemented_simpleFunctionObject::movePoints true; type swakExpression; valueType surface; surfaceName interface; verbose true; expression "pow(pos().y-yAvg,2)*area()/sum(area())"; variables "yAvg=sum(pos().y*area())/sum(area());"; accumulations ( sum ); } velocity { ignore_unimplemented_simpleFunctionObject::movePoints true; type swakExpression; valueType surface; surfaceName interface; verbose true; expression "mag(U)"; accumulations ( max ); } swakSurfInterface { ignore_unimplemented_simpleFunctionObject::movePoints true; type surfaces; outputControl outputTime; // outputControl timeStep; outputInterval 1; fields ( U ); surfaceFormat vtk; surfaces ( interface { type swakRegistryProxy; surfaceName interface; } ); interpolationScheme nix; } DropDownVelocity { aliases { alphawater alpha.water; } type swakExpression; valueType internalField; variables ( "downDirection=vector(0,-1,0);"//select the downwards direction "thres=0.5;"//which cells to keep "liquidVol= sum(alphawater > thres ? vol() : 0);" //calculates the volume of the drop "downVel= alphawater > thres ? (U & downDirection) : 0;" //a & b:inner vector product. Keep the y component of U. ); expression "downVel*vol()/liquidVol";//vol():vol of the cell accumulations ( sum ); verbose true; } ); any comment is appreciated, regards, |
March 7, 2017, 09:31 |
behzad Ghasemi
Rep Power: 13 |
According to attached Error.txt file, the shared object libtwoPhaseInterfaceProperties.so isn't exist in openFoam library any more. maybe there was in older versions, now i have two questions:
1- Do i need libtwoPhaseInterfaceProperties.so for creating and tracking droplet interface or only libinterfaceProperties.so will suffice? 2- If i need libtwoPhaseInterfaceProperties.so, can i add this to openFoam library? and how? Any comment is appreciated, Kind regards, Last edited by behzad-cfd; March 7, 2017 at 18:01. |
March 16, 2017, 10:22 |
behzad Ghasemi
Rep Power: 13 |
No one have an idea?
March 25, 2017, 17:19 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Behzad,
I've finally managed to take a quick look into this and I have to say that I'm a bit confused, mostly because I'm not familiar with the reason why you're loading all of those libraries in the "libs" list within "controlDict". As for the log file from the installation, only fieldReport didn't build, so this shouldn't affect your case. Therefore, to address the problem, I suggest that you change the "libs" entry to this: Code:
libs ( "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" ); Of course this also means that you must only use these with the correct multiphase solver and do not try to use these function objects with an application such as execFlowFunctionObjects. Best regards, Bruno
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM | steven123 | OpenFOAM Community Contributions | 35 | January 11, 2021 17:53 |
[swak4Foam] Problem to calculate grad(U) using swak4Foam | Hugoles | OpenFOAM Community Contributions | 12 | November 24, 2020 11:28 |
[swak4Foam] [OpenFOAM plus] [v1612+] swak4Foam installation problem in Windows (Allwmake) | LThomes | OpenFOAM Community Contributions | 7 | October 6, 2020 14:36 |
[swak4Foam] Installing swak4Foam with openFoam v3.0+ | RebelLion | OpenFOAM Community Contributions | 0 | March 11, 2016 20:10 |
[swak4Foam] swak4foam 0.3.2 installation problem on Ubuntu 15.04 with OpenFOAM 2.4.0 | ptsxx | OpenFOAM Community Contributions | 1 | January 10, 2016 18:48 |
