[PyFoam] customRegexp with pyFoamPlotWatcher.py for force coefficents
Old   February 27, 2017, 12:26
Default customRegexp with pyFoamPlotWatcher.py for force coefficents
BendikS is on a distinguished road
I'm trying to make a custom regular expression for my force coefficients so I can plot them on the fly with pyFoamPlotWatcher.py, but I'm not really sure on how my customRegexp file should look like. Does anybody have an working example?
My force coefficient output looks like this btw:
forceCoeffs forceCoeffs output:
    Coefficients
        Cm       : -2.34093e-05    (pressure: -2.32145e-05    viscous: -1.94815e-07)
        Cd       : -0.010548    (pressure: -0.0105261    viscous: -2.18705e-05)
        Cl       : -0.010548    (pressure: -0.0105261    viscous: -2.18705e-05)
        Cl(f)    : -0.00529742
        Cl(r)    : -0.0052506
Thanks!
BendikS is offline   Reply With Quote
Old   March 30, 2017, 09:06
Anyone? Or can someone point me in a direction where I could find more resources for customregexp for pyfoam?
Old   January 31, 2018, 12:15
Lennart
elmo555 is on a distinguished road
You can create one regexp for each line of your force coefficient output, and then use the new master-slave feature to merge all data into a single plot.
This is how your file customRegexp could look like:
dragOF5 {
	theTitle "Forces";
	expr "Cd += (%f%)";
	titles ("Drag Coeff");
dragOF5slave
	expr "Cl += (%f%)";
	titles ( "Lift Coeff" );
	type slave;
	master dragOF5;
The regular expression is told that there might be an arbitrary number of spaces between the keyword "Cd" and the equal sign using the plus sign.
More info on how to create these files can be found here: http://openfoamwiki.net/index.php/Co...oam#New_format
elmo555 is offline   Reply With Quote
customregexp, force coefficients, pyfoam, pyfoam customregexp, pyfoamplotwatcher.py
[PyFoam] Using pyFoamPlotWatcher.py To Plot Residuals m_ridzon OpenFOAM Community Contributions 22 January 26, 2021 19:48
How to caculate the coefficents in sylindical sys Kevin Siemens 1 March 17, 2006 00:04
