[ImmersedBoundary] Immersed Boundary method mesh refinement problem |
February 8, 2017, 12:09 |
#1 | |
Thamali
Rep Power: 13 |
Hi foamers,
I am trying to run icoIbFoam including energy equation to see flow around a 1mm,spherical particle with 350K constant temperature.I refined the mesh and it is attached. Since the results were showing very high Courant numbers and very high velocitites,etc with very high mesh refinement(attached one is after reducing mesh refinement and without rapid mesh rerinement),I changed the solver to vary deltaT to adjust to make Courant number less than 1.But, still the velocities go around 100s.My inlet velocity is (0.1569 0 0). velocity boundary condition; Quote:
My domain size is 40mm*20mm*20mm. The results seems making an error due to mesh refinement problem.I used the method like in sphereInChannel for refinement. Can someone help me to figure out my proble? Thanks in advance. Thamali |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
