January 31, 2017, 08:12 |
Helyx-OS 2.4.0 and cell zone
Jussi Kangas
Rep Power: 11 |
Hello
I recently updated to OF1606 and helyx os 2.4.0, I did find some pleasant enchantments. But my main concern is how to create cell zones in this new version. Until now I have been creating cylinder to cover rotating part of fluid volume. Then defined it as internal and cell zone. After that meshing. Now only thing that can create cell zone without error is plane. What im missing????? Anyone else having a same problem? I attached simple fan in duct picture to present this problem. |
January 31, 2017, 13:54 |
Jussi Kangas
Rep Power: 11 |
Hello
It is good to go trough all basics, I'm not professional in CFD. Just using it for my own hobbies.. This time solution was not that easy. Material point is not shown in picture and it does locate inside fluid volume. Other ideas what to test? |
January 31, 2017, 15:20 |
Rep Power: 15 |
We are all learning
The material point is inside the cellzone or outside but inside the fluid volume? It is different. I have yet to understand why the cylinder is bigger than the rotating part... Perhaps is easier if you upload the case file. Best Regards, RS |
February 1, 2017, 03:48 |
Jussi Kangas
Rep Power: 11 |
Hello
I did try those as well. I made cylinder smaller than flow area and moved material point inside rotating zone, as well as out side it, but still in fluid volume. no effect still gives same error. Where I need it to go over... well my hobby is centrifugal compressors. When I'm simulating a compressor wheel, usually I take inlet, wheel and diffuser. Form a air volume from these. Then I use cylinder object to "make inlet" and second one to I use over impeller area to determine MRF area. As impeller is not shaped like cylinder, I use bigger cylinder to cover impeller area for making cell zone. See other picture as well. |
February 1, 2017, 11:05 |
Rep Power: 15 |
Hello jsskangas,
From the pictures it seems you are going through the Helyx-os workflow correctly. Could you upload your case file? I think it would be easier to see whats going on. Best. RS |
February 1, 2017, 11:53 |
Jussi Kangas
Rep Power: 11 |
February 1, 2017, 12:49 |
Daniel P. Combest
Jussi,
I was able to generate a cellZone with your surfaces by doing the following:
In this test case you may want to separate out your impeller and your walls since the MRF model will need to treat non-moving walls in an MRF zone a little differently (unless you want those walls to move too) |
February 1, 2017, 13:00 |
#9 |
Jussi Kangas
Rep Power: 11 |
Hello
Thanks but not possible to do that in my project. This blower in a duct was just quick and small example to demonstrate this problem. In my real cases I can not always use it that way. I think this could be a bug on Helyx-os. |
February 1, 2017, 13:07 |
#10 |
Daniel P. Combest
Ah ok, those were just some suggestions. I re-downloaded your case, loaded it in HELYX OS and just pressed mesh and created a mesh with an MRF region. From that I'd say it's not a bug in HELYX-OS. I can't reproduce the issue with your current test case.
February 1, 2017, 13:18 |
#11 |
Jussi Kangas
Rep Power: 11 |
What version of helys-os you are using?
It works fine with older version, but we are now talking with 2.4.0 version of helyx-os and OF1606+. Jussi |
February 1, 2017, 13:50 |
#12 |
Daniel P. Combest
I'm using HELYX-OS version 2.4.0 and OpenFOAM 4 from the Ubuntu repository.
February 1, 2017, 14:18 |
#13 |
Jussi Kangas
Rep Power: 11 |
Hello
Could anyone test my setup with helyx-os 2.4.0 ans OF1606+. with my setup will it give same error? Then I could revert back to OpenFoam 4.0 if meshing works with that properly. |
February 3, 2017, 11:22 |
#14 |
Daniel P. Combest
This is a bug in 1606 snappyHexMesh dealing with an additional method zones are detected/set. The old method, user specified faceTypes and cellZone names (which you are using). The new alternative method uses an additional list of points and zone names.
February 4, 2017, 08:21 |
#15 |
Jussi Kangas
Rep Power: 11 |
Hello
I installed OF4.0 now meshing work fine. Thanks everyone for reply. Jussi |
Setting cell variable values in a fluid zone using UDF | eromon84 | Fluent UDF and Scheme Programming | 6 | March 28, 2021 11:59 |
Overlap and gap between cell zone for sliding mesh | cs12345 | FLUENT | 2 | December 14, 2017 08:41 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 12:25 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 15:52 |
