[swiftBlock/swiftSnap] SwiftSnap is throwing an error on save |
December 13, 2016, 03:23 |
Rep Power: 10 |
I have recently installed Blender and SwiftSnap, although I have run into a little snag. I can create a model, assign faces/patches etc, however when I attempt to 'Write', I get an error : "TypeError: save() got multiple values for argument 'filepath'". I have tried to cross a few things from the list:
I am a bit lost - has anyone else seen this before? |
December 13, 2016, 04:06 |
Karl-Johan Nogenmyr
Rep Power: 21 |
Hmm.. haven't seen this. What Blender version are you running? Do you mind sharing the full path and filename you try to use?
Kalle |
December 13, 2016, 06:53 |
Rep Power: 10 |
Thanks for the quick reply.
I'm running Blender 2.77. I should have mentioned this is a Windows 10 environment rather than a Linux environment. The full path of the script is: "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.77\scripts\addons\swiftSnap-master" The full path of the attempted export is: "C:\Users\No\CAE\FWR_Eyeball", with a ".blend" file in that directory named either "FWR_Eyeball.blend" or "untitled.blend". I have tried other directories (such as My Documents), but I get the same result. The error I get looks like this: |
December 13, 2016, 06:58 |
Karl-Johan Nogenmyr
Rep Power: 21 |
Hmm... probably some change in Blender's API is to blame for this. SwiftSnap is working with 2.70 - 2.72. Can you try to install that version instead? Old version are found on blender's website.
K |
December 13, 2016, 22:16 |
Rep Power: 10 |
It would appear that Blender has changed its API - version 2.72 works just fine.
Thanks for your help! |
blender, swiftsnap |
Very quick - Journal file command to save monitors | lcaBR | FLUENT | 2 | October 18, 2022 13:26 |
save to variable filename inside loop | FrankR | Fluent UDF and Scheme Programming | 5 | January 30, 2019 12:16 |
save case & data | Saman95 | FLUENT | 1 | August 12, 2018 07:09 |
[General] Save Animation Settings | TomBot | ParaView | 2 | August 26, 2017 08:54 |
terminate called after throwing an instance of 'int' | b614910 | SU2 | 10 | July 27, 2014 23:16 |
