[swak4Foam] how to access a variable from "sources" for writing a SWAK-EXPRESSION
Old   December 1, 2016, 04:28
Default how to access a variable from "sources" for writing a SWAK-EXPRESSION
a
cfd@kgp is on a distinguished road
Dear FoAMERs'
There is a variable named as alpha1_ in one of the derived sources named as "solidificationMeltingSource" defined in "solidificationMeltingSource.H
volScalarField alpha1_;
also in "solidificationMeltingSource.C" it is defined as IOobject
alpha1_
IOobject
name_ + ":alpha1",
mesh.time().timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("alpha1", dimless, 0.0),
zeroGradientFvPatchScalarField::typeName
when I am using the source through "buoyantPimpleFoam" solver/application,
the swakexpression cannot recognize alpha1 variable.
But as alpha1 is a IO object in output files the field of alpha1 is written as output, here it name is printed as "sMS1:alpha1" ( sMs1 is a name provided to the set of input variables in contant directory in fvOptions file)
by any way swak4Fom/functions/coding please guide me so that I can calculate some derived quantities using this field of alpha1 for every time step.
I am not a expert in C language so please instruct me in detail.
Anxiously waiting for a any kind of help
Regards.
cfd@kgp is offline   Reply With Quote
Old   December 1, 2016, 07:49
Default How to define a global variable in application--globalfor src/ utilities?
a
How to define a global variable in application such that the src/....../derived sources can update it
Any new scalar created in application or meltingandsolidificationsources they are not global and we cannot transfer the information from one (application or src ) to other (src or application ).
I am very new to C++ and openfoam programming kindly help...
[swak4Foam] is it possible to exclude some faces in calculating an expression on a patch in SWAK? immortality OpenFOAM Community Contributions 12 August 14, 2013 23:52
Error: access: unbound variable Shriram Main CFD Forum 0 June 22, 2007 09:31
Error : access : Unknown variable & Phase-domain MKP FLUENT 0 August 28, 2006 04:40
Error: access: unbound variable vivek FLUENT 0 June 6, 2005 07:05
Error: access: unbound variable cfd-novice FLUENT 0 April 3, 2003 05:53
