[ImmersedBoundary] Immersed Boundary Mesh Problem |
November 20, 2016, 16:05 |
#1 | |
Emre
Rep Power: 11 |
I did cylinderInChannelIcoIbFoam and movingCylinderInChannelIco tutorials succesfully. (https://github.com/wyldckat/Immersed...annelicoIbFoam and https://github.com/Unofficial-Extend...erInChannelIco) I want to define new cylinders instead of tutorials' cylinders. I created it in ANSYS DesignModeller and made it as surface body, then meshed. At this point I have cylinder.msh Now I want to change this .msh file to .stl in order to use it in immersed boundary tutorials. I typed fluentMeshToFoam cylinder.msh. I get fatal error. cannot find a single face in the mesh which uses vertices 3(1 0 2) From function findFace(const primitiveMesh&, const face&) in file fluentMeshToFoam.L at line 856. Then I typed fluent3DMeshToFoam cylinder.msh. It worked. After this I tried this method to create cylinder.stl : Quote:
Any idea? |
November 21, 2016, 04:47 |
Anton Kidess
Rep Power: 30 |
If all you need is a cylinder, make it in Paraview, triangulate the geometry (filter) and save data to STL. Apart from that Ansys DM cannot export STL? Really surprises me.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
November 21, 2016, 05:23 |
Emre
Rep Power: 11 |
Even if Ansys Design Modeler could export STL, I wouldn't need it. I need a mesh file because I want to set the delS (I mean delta S in immersed boundary and it has to be equal to delta X in blockmesh) and to convert it STL.
foam-extend-3.2, immersed boundary, immersed boundary method |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
