[ImmersedBoundary] Immersed Boundary foam-ext 3.2 Parallelization for higher amount of MPI tasks |
October 11, 2016, 04:50 |
Rep Power: 12 |
Hi guys,
I observed a little bug regarding the IB Method of Jasak and its parallelization. Meanwhile the immersed boundary region is not decomposed over different cores, the IB implementation runs in parallel. Nevertheless, if the Immersed Boundary regionis decomposed over different cores, an error occurs. Code:
Create time Create mesh for time = 0 Create immersed boundary cell mask Create immersed boundary face mask Found immersed boundary patch 0 named ibCylinder [3] Number of IB cells: 0 [6] Number of IB cells: 0 [7] Number of IB cells: 0 External flow [2] Number of IB cells: 0 [5] Number of IB cells: 0 [4] Number of IB cells: 0 [0] Number of IB cells: 63666 [1] Number of IB cells: 81786 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 5e-05 Courant Number mean: 0.00304818143 max: 1.81649312 velocity magnitude: 2.35556273 *** Error in `icoIbFoam': free(): invalid next size (normal): 0x000000002468a800 *** ======= Backtrace: ========= /lib64/libc.so.6(+0x7410f)[0x2b80e90ea10f] /lib64/libc.so.6(+0x7996e)[0x2b80e90ef96e] /lib64/libc.so.6(+0x7a647)[0x2b80e90f0647] /home/iagaxtma/opt/foam/foam-extend-3.2/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam4ListINS_4PairIiEEE7setSizeEi+0x42)[0x2b80e59ded72] /home/iagaxtma/opt/foam/foam-extend-3.2/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch15makeIbCellCellsEv+0x1c38)[0x2b80e72526b8] /home/iagaxtma/opt/foam/foam-extend-3.2/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch11ibCellCellsEv+0x1d)[0x2b80e7252a0d] Nevertheless I would like to fix this bug, the problem is, I do not really know where to start. I had a deeper look in the Immersed Boundary Implementation files, but somehow I am missing the important part. Any hint would be appreciated and maybe Prof Jasak has an advice. Thanks |
October 12, 2019, 10:34 |
Rep Power: 7 |
Hello hxaxtma, I know this post is old now, but I am running into the same issue you suggested (crashing when the immersed boundary crosses between processors).
Could you please let me know how you were able to create a faceZone to get around this problem? Thanks! |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
segmentatio fault using cyclic boundary conditions in FOAM extend 3.2 | GFarello | OpenFOAM Running, Solving & CFD | 2 | January 18, 2017 06:27 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 03:21 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
