[cfMesh] problem with symmetryPlane
Old   October 3, 2016, 11:14
Default problem with symmetryPlane
Joris C.
Coris is on a distinguished road
I have a problem activating the symmetryPlane BC for one of my boundaries when the mesh is made with cfMesh. This is a known problem, because cfMesh comes with a utility 'improveSymmetryPlanes'. However, this is not enough for the case at hand..
checkMesh before running improveSymmetryPlanes:
--> FOAM FATAL ERROR:
Symmetry plane 'frontSymmetry' is not planar.
At local face at (0.1703081812887766 0.001158095292908665 1.601390638203566e-21) the normal (-1.211793931078213e-17 -4.239402769195217e-18 -1) differs from the average normal (3.522462206000439e-06 1.550530335361962e-07 -0.9999999996709624) by 1.243178154426267e-11
Either split the patch into planar parts or use the symmetry patch type
From function void Foam::symmetryPlanePolyPatch::calcGeometry(Foam::P streamBuffers &)
in file meshes/polyMesh/polyPatches/constraint/symmetryPlane/symmetryPlanePolyPatch.C at line 64.
and after:
At local face at (0.1703081812888498 0.001158095292911979 -6.686652924327499e-08) the normal (1.094760291316228e-06 4.90293024478426e-08 -0.9999999999993996) differs from the average normal (6.28184762184831e-07 4.89799734796166e-08 -0.9999999999492696) by 2.176927293306086e-13
FOAM exiting
so definitely, there is an improvement, but not enough.
I have tried some stuff, ie:
- flattenMesh utility, by temporarily changing the symmetryPlane to empty --> messes up the mesh (edit: this is normal, because flattenMesh supposes a 2D geometry and acts on all nodes/points)
- changing the meshing in the neighbourhoud of the problem area --> no effect
- controlDict: increasing writePrecision --> no effect
- controlDict: binary instead of ascii --> improveSymmetryPlanes doesn't work
I would rather not change to symmetry bc instead of symmetryPlane, because I strongly suspect this is the cause for not being able to converge the simulation I am running with the mesh.
Any other ideas?
Unfortunately, I cannot upload my current model and the minimal working example I have, doesn't display this behaviour.
Coris is offline   Reply With Quote
cfmesh
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
