[ImmersedBoundary] Conjugate Heat Transfer with Immersed Boundary Method (fe-3.2)
Old   May 30, 2016, 10:30
Default Conjugate Heat Transfer with Immersed Boundary Method (fe-3.2)
SeMar is on a distinguished road
Dear foamers,
I'm trying to modify the icoIbFoam in the latest foam-extend release 3.2. The idea is, adding a temperature diffusion/convection-equation to the code in order to simulate a conjugate-heat-transfer problem. So far I've implemented a modified "DT" Field
DT = cellIbMask * lambdaF / (rhoF * CpF) + (1-cellIbMask) * lambdaS / (rhoS * CpS);
All the values xF, xS (fluid, solid) are lookup values from the transportPropertiesDict.
In the solverloop I added
fvScalarMatrix TEqn
            fvm::ddt(T)
            + fvm::div(phi, T)
            - fvm::laplacian(DT, T)
TEqn.solve();
T.correctBoundaryConditions();
While temperature is being calculated in the fluid cells, the value of the Ib-cells does not change. I tried several combinations of 'setDeadCellValue' and 'fixesValue' in the 0/T BC file and also erased the 'T.correctBoundaryConditions();' without success. Setting a temperature manually in the code however works. So I guess there must be something preventing the immersed boundary cells from being solved. Does anybody have a clue, where to find the corresponding lines of code?
Thanks in advance
Sebastian
SeMar is offline   Reply With Quote
Old   June 22, 2016, 07:12
Talking Have you had success?
XuDongNa
supersoldier is on a distinguished road
Send a message via ICQ to supersoldier
Recently , I also want to do some work like yours, so have you had success?
supersoldier is offline   Reply With Quote
Old   June 22, 2016, 11:09
No, unfortunately not. But I'm still very interested in a solution.
Old   June 24, 2016, 02:05
XuDongNa
Originally Posted by SeMar View Post
Dear foamers,
fvScalarMatrix TEqn
            fvm::ddt(T)
            + fvm::div(phi, T)
TEqn.solve();
Thanks in advance
Sebastian
what do you mean by "Setting a temperature manually in the code however works" ? I posted a thread at http://www.cfd-online.com/Forums/ope...tml#post606287 . #67.
Can you give me some advance?
Old   June 24, 2016, 04:22
By manually I mean assigning a value to the field.
T = 300.0;
This would result in every cell of field T including immersedboundary cells having a value of 300.0.
foam extend 3.2, heat exchange, immersed boundary, programming
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
