[cfMesh] using surfaceFeatureEdges for cfMesh |
May 10, 2016, 02:50 |
Rep Power: 12 |
I am using cfMesh for about 6 months and I am so satisfied with this Meshing-Tool, thanks a lot! This is my commonly used workflow:
If I convert a complex stl-file to a fms- or ftr-file with surfaceFeatureEdges (I'm used to it) I will get the following error: Code:
Segmentation fault (core dumed) Thx |
May 25, 2016, 05:09 |
#2 | |
I have had problems importing large stl files because some indices used to go out of scope. This usually happened with triangulations consisting of more that 15 million triangles. If that is the case, you will have to make your triangulation coarser.
Principal Developer of cfMesh and CF-MESH+ www.cfmesh.com Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram |
June 14, 2016, 04:11 |
Rep Power: 12 |
yes, you are right. The stl-file which I used was too large and complex. Thank you!
cfmesh |
[cfMesh] missing feature edges of coplanar patches when using surfaceFeatureEdges (cfMesh) | cutter | OpenFOAM Community Contributions | 1 | August 20, 2015 16:47 |
