[waves2Foam] compiling a new solver with wmake: waveDyMFoam |
April 11, 2016, 14:53 |
Anna
Rep Power: 10 |
Dear all
I am writing to ask question about installing waves2Foam. I installed OpenFoam211 on ubuntu 10.4 and now I am trying to install waves2Foam. But the compilation didnt complete and some errors were seen as an example: /usr/bin/ld: cannot find -lwaves2Foam But it seems that the bashrc file of waves2Foam has some problems and i think it relates to the following line: WAVES_APPBIN=$FOAM_USER_APPBIN WAVES_LIBBIN=$FOAM_USER_LIBBIN it seems that $FOAM_USER_APPBIN and $FOAM_USER_LIBBIN dont exist or the directions of them are not correct but i dont know the correct direction. Does anybody encounter this problem? Best Regards Anna |
April 19, 2016, 17:15 |
Anna
Rep Power: 10 |
Dear All
I have just install waves2Foam and run an example and actually in worked without any problem. Now I am trying to compile that with interDyMFoam solver and for that I followed the steps written at https://openfoamwiki.net/index.php/Contrib/waves2Foam. But when I tried to compile with wmak, I encounter some errors as below: root@anna-VPCF13EFX:~/OpenFOAM/anna-2.4.0/applications/utilities/waves2Foam/applications/solvers/solvers240/waveFoam/waveDyMFoam# wmake linuxGccDPOpt/options:59: *** missing separator. Stop. wmake error: file 'Make/linuxGccDPOpt/objectFiles' could not be created in /home/anna/OpenFOAM/anna-2.4.0/applications/utilities/waves2Foam/applications/solvers/solvers240/waveFoam/waveDyMFoam root@anna-VPCF13EFX:~/OpenFOAM/anna-2.4.0/applications/utilities/waves2Foam/applications/solvers/solvers240/waveFoam/waveDyMFoam# Actually I cant understand how to solve this problem. do you have the answer? Best Regards Anna |
April 19, 2016, 19:38 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick request: Please provide the contents of the file "Make/options".
April 20, 2016, 12:37 |
Anna
Rep Power: 10 |
Dear All
April 20, 2016, 12:48 |
problem with wmake
#5 | |
Anna
Rep Power: 10 |
This is the content of make/option (with the changes): Code:
EXE_INC = \ -I.. \ -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \ -I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/dynamicMesh/lnInclude \ -I$(LIB_SRC)/dynamicFvMesh/lnInclude \ -I./../../../../../src/lnInclude -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/fvOptions/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude EXE_LIBS =\ -limmiscibleIncompressibleTwoPhaseMixture \ -lincompressibleTurbulenceModel \ -lincompressibleRASModels \ -lincompressibleLESModels \ -lfiniteVolume \ -ldynamicMesh \ -ldynamicFvMesh \ -ltopoChangerFvMesh \ -lmeshTools \ -lfvOptions \ -lsampling -L$(FOAM_USER_LIBBIN) \ -lwaves2Foam Last edited by wyldckat; April 20, 2016 at 18:07. Reason: Added [CODE][/CODE] markers |
April 20, 2016, 18:09 |
Bruno Santos
Rep Power: 128 |
Quick answer: The lines you've added are missing a backslash "\" at the end of the line on the previous line. The following should work as intended:
EXE_INC = \ -I.. \ -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \ -I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/dynamicMesh/lnInclude \ -I$(LIB_SRC)/dynamicFvMesh/lnInclude \ -I./../../../../../src/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/fvOptions/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude EXE_LIBS =\ -limmiscibleIncompressibleTwoPhaseMixture \ -lincompressibleTurbulenceModel \ -lincompressibleRASModels \ -lincompressibleLESModels \ -lfiniteVolume \ -ldynamicMesh \ -ldynamicFvMesh \ -ltopoChangerFvMesh \ -lmeshTools \ -lfvOptions \ -lsampling \ -L$(FOAM_USER_LIBBIN) \ -lwaves2Foam |
April 21, 2016, 04:44 |
Kevin van As
Rep Power: 21 |
That line is probably telling you what goes wrong.
Your Make/options file is incorrect: it is missing a separator. If I take interFoam as an example, the following snippet will give the same error you are getting. The red line is wrong. Code:
EXE_INC = \ -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \ -I$(LIB_SRC)/transportModels -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \ -I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/fvOptions/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude Code:
EXE_INC = \ -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \ -I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/fvOptions/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude |
April 22, 2016, 06:40 |
#8 | |
Anna
Rep Power: 10 |
First thank you for your quick reply. I made these mentioned changes and then tried wmake, but I encounter some other errors as bellow: Code:
anna@anna-VPCF13EFX:~/OpenFOAM/anna-2.4.0/applications/utilities/waves2Foam/applications/solvers/solvers240/waveFoam/waveDyMFoam$ wmake SOURCE=waveDyMFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I.. -I/opt/openfoam240/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam240/src/transportModels -I/opt/openfoam240/src/transportModels/incompressible/lnInclude -I/opt/openfoam240/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam240/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam240/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam240/src/finiteVolume/lnInclude -I/opt/openfoam240/src/dynamicMesh/lnInclude -I/opt/openfoam240/src/dynamicFvMesh/lnInclude -I./../../../../../src/waves2Foam/lnInclude -I/opt/openfoam240/src/meshTools/lnInclude -I/opt/openfoam240/src/fvOptions/lnInclude -I/opt/openfoam240/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam240/src/OpenFOAM/lnInclude -I/opt/openfoam240/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/waveDyMFoam.o In file included from waveDyMFoam.C:61:0: ../createFields.H: In function ‘int main(int, char**)’: ../createFields.H:141:5: error: declaration does not declare anything [-fpermissive] relaxationZone ;relaxing(mesh, U, alpha1); ^ ../createFields.H:141:45: error: ‘relaxing’ was not declared in this scope relaxationZone ;relaxing(mesh, U, alpha1); ^ In file included from waveDyMFoam.C:62:0: /opt/openfoam240/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable] scalar maxDeltaT = ^ make: *** [Make/linuxGccDPOpt/waveDyMFoam.o] Error 1 I appreciate your kindness in advance Best Regards Anna Last edited by wyldckat; May 1, 2016 at 20:24. Reason: Added [CODE][/CODE] markers |
May 2, 2016, 04:21 |
#9 |
Anna
Rep Power: 10 |
Hi Foamers
I am trying to compile waveDyMFoam. I just did the steps written on the openfoamwiki.net, but now i dont know how to understand that the compilation is done. the message after wmake command is : anna@anna-VPCF13EFX:~$ of240 anna@anna-VPCF13EFX:~$ cd /home/anna/OpenFOAM/anna-2.4.0/applications/utilities/waves2Foam/applications/solvers/solvers240/waveFoam/waveDyMFoam anna@anna-VPCF13EFX:~/OpenFOAM/anna-2.4.0/applications/utilities/waves2Foam/applications/solvers/solvers240/waveFoam/waveDyMFoam$ wmake make: `/home/anna/OpenFOAM/anna-2.4.0/platforms/linuxGccDPOpt/bin/waveDyMFoam' is up to date. Is the compilation done correctly? Best Regards Anna |
May 3, 2016, 04:05 |
#10 |
Kevin van As
Rep Power: 21 |
If it doesn't give an error, it completed successfully.
In your case, you are trying to recompile it, while nothing in the source code since the last successful compilation. It then says it is "up to date". This should mean that it was previously compiled successfully. In the Make/files file you can see where the executable is moved to. This is typically to $FOAM_USER_APPBIN for custom solvers. If there is an executable in that directory, you too know it was compiled successfully (or an old version resides there). |
May 3, 2016, 11:17 |
#11 |
Anna
Rep Power: 10 |
Thank you for your useful reply. I checked the location and the executable file of waveDyMFoam was included. But now I do not know how to recall the tutorials of the waveDyMFoam. Actually I dont know weather there is a tutorials or with this compilation I can just use the wave as boundary condition in interDyMFoam.
I appreciate your kindness in advance Best Regards Anna |
October 16, 2016, 11:24 |
compiling waveDyMFoam solver with wmake
#12 |
Anna
Rep Power: 10 |
Dear Friends
I am trying to compile waveDyMFoam with interDyMFoam. Although I have followed the steps written on the wiki, I encounter some problems. The compilation has not completed yet and I do not know how to solve the problem. I would be very grateful if you help me. shima@shima:~/OpenFOAM/shima-2.4.0/applications/utilities/waves2Foam/applications/solvers/solvers240/waveFoam/waveDyMFoam$ wmake Making dependency list for source file waveDyMFoam.C could not open file relaxationZone.H for source file waveDyMFoam.C due to No such file or directory could not open file readWaveProperties.H for source file waveDyMFoam.C due to No such file or directory SOURCE=waveDyMFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I.. -I/opt/openfoam240/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam240/src/transportModels -I/opt/openfoam240/src/transportModels/incompressible/lnInclude -I/opt/openfoam240/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam240/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam240/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam240/src/finiteVolume/lnInclude -I/opt/openfoam240/src/dynamicMesh/lnInclude -I/opt/openfoam240/src/dynamicFvMesh/lnInclude -I./../../../../../src/waves2Foam/lnInclude -I/opt/openfoam240/src/meshTools/lnInclude -I/opt/openfoam240/src/fvOptions/lnInclude -I/opt/openfoam240/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam240/src/OpenFOAM/lnInclude -I/opt/openfoam240/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/waveDyMFoam.o waveDyMFoam.C:47:28: fatal error: relaxationZone.H: No such file or directory #include "relaxationZone.H" ^ compilation terminated. make: *** [Make/linuxGccDPOpt/waveDyMFoam.o] Error 1 Best Regards Anna |
October 18, 2016, 17:29 |
#13 | |
Ehsan Asgari
Rep Power: 18 |
It is complaining that relaxationZone.H cannot be found within classes and libraries you have provided in Make/options. You should look for the folder containing that class and include it in the options. Syavash |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 16:44 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 07:29 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
