[swak4Foam] multiphase mass-flow monitor with swak4Foam
Old   March 29, 2016, 05:04
Default multiphase mass-flow monitor with swak4Foam
Paritosh Vasava
vasava will become famous soon enough
I am simulating fluid+solid flow with multiPhaseEulerFoam solver and monitoring the solid mass flow across patches using the following:
    solids1 {
        type patchExpression;
	aliases {alphasolids alpha.solids;
		 Usolid U.solids; }
        patches (
	water_inlet
	outlet1
	outlet2
	outlet3
        verbose true;
        expression "mag(sum(normal()&Usolid*alphasolids*area()*998.2))";
        accumulations (
            average
	outputControl timeStep;
        outputInterval 10;
However when I check the mass balance (the same way as I would do in Fluent) I get 5-10% error. This expression is from swak4Foam tutorial example.
Am I doing something wrong?
vasava is offline   Reply With Quote
massflow monitor, swak4foam
[swak4Foam] error when use swak4foam to calculate the mass flow rate of a cutting plane ozs OpenFOAM Community Contributions 0 September 4, 2017 23:52
Multiphase flow in a pipe with a CHT wissal CFX 4 June 12, 2017 13:15
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
