[swak4Foam] funkyDoCalc write fields
Old   March 24, 2016, 07:44
Default funkyDoCalc write fields
Timm Severin
Astrodan is on a distinguished road
Note: Solved. Turns out funkySetFields actually is the solution to what I want, since this tool only requires a dummy field to be prepared that can then be filled with the desired expression.
For further reference, below the original post.
Hey guys,
I'm currently trying to evaluate my simulation, and would need to do some calculations. As foamCalc is quite incapable of anything, I figured funkyDoCalc was the way to go.
But as far as I understood the source code, it appears that the utility only writes information to STDOUT and a file that is similar to the postProcessing stuff. Am I missing something, or is it simply not possible to write new (internal/boundaryFields) to a time-folder?
I also tried to add the lines
driver->createWriterAndRead(name)
driver->tryWrite()
to the funkyDoCalc.C right after it evaluated the expression, but got no result.
I called the tool with funkyDoCalc -latestTime testDict.
My testDict used for the utility, which should be usable with any case that calculates U:
FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      controlDict;
uSqr
    valueType   internalField;
    expression  "mag(U)";
    accumulations (
        average
Astrodan is offline   Reply With Quote
foamcalc, funkydocalc, swak4foam
chtMultiRegionSimpleFoam does not write converged time step Tobi OpenFOAM Bugs 6 October 14, 2017 12:41
modify pimpleFoam to write sampled fields on a patch each runtime moh-farmani OpenFOAM Programming & Development 0 August 19, 2017 16:17
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 10:15
write nut fields in simpleFoam maurice OpenFOAM Running, Solving & CFD 5 March 23, 2009 02:57
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
