[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison |
March 14, 2016, 09:19 |
Lee
Rep Power: 10 |
Dear OpenFOAM users,
I am now trying to install foam-extend-3.2 on Ubuntu. I follow the installation tutorial found at OpenFOAM wiki, but got an error as follow. Code:
Swak version is 0.3.1 Bison is version 3.0.2 swak4Foam only confirmed to work with Bison 2.x Consider running ./maintainanceScripts/compileRequirements.sh for a local bison-installation Set the environment variable DEVELOP_FOR_NEW_BISON if you want to continue anyway. Requirements for library not satisified. I see no sense in going on Check README .... your problem occured to 5 other people before and has been solved on .. Code:
./maintainanceScripts/compileRequirements.sh the above error at Stage5, how can I continue the compiling process? Thanks in advance. Xuan |
March 20, 2016, 17:03 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Xuan and welcome to the forum!
I didn't fully understand if you had managed to build/install swak4Foam or not. If you did manage to install it, then everything is now probably built as intended in foam-extend 3.2. If you didn't build/install swak4Foam, then please try the following commands: Code:
cd $WM_THIRD_PARTY_DIR/rpmBuild/BUILD/swak4Foam-0.3.2 ./Allwclean ./Allwmake > log.make 2>&1 Best regards, Bruno
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 10:54 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
