[SOWFA] NREL SOWFA Tutorial case
Old   March 8, 2016, 11:35
Unhappy NREL SOWFA Tutorial case
Mohsen
mohsen.boojari is on a distinguished road
hi everyone,
I'm trying to run a test case in SOWFA package named (NREL5MWRef.uniformFlow)
but when i used the runscript of this case to start the simulation i got these errors:
cp: cannot stat `0.original': No such file or directory
cp: cannot stat `system/controlDict.1': No such file or directory
Running blockMesh
cp: cannot stat `constant/polyMesh/blockMeshDict': No such file or directory
mv: cannot stat `./blockMeshDict': No such file or directory
Also these ones:
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/mohsen/system/controlDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
All of the above mentioned files exist in the case File but i don't know why I'm seeing this.
I have attached the Script . please take a look at it .
thanks
#!/bin/bash
#PBS -l walltime=72:00:00
#PBS -l nodes=40
#PBS -A windFlowModeling
#PBS -W x="FLAGS:ADVRES:SOWFA.10113"
source $HOME/.bash_profile
OpenFOAM-2.0.x-gcc-impi
module list
cd $PBS_O_WORKDIR
nodes=40                             # Number of nodes
cores=24                             # Number MPI processes to start on each node; 8 cores/node
solver=pisoFoamTurbine
refineMeshLocal()
   i=$1
   while [ $i -gt 0 ]
   do
      echo "Performing level $i local refinement"
      echo "   selecting cells to refine..."
      cp system/topoSetDict.local.$i system/topoSetDict
      topoSet > log.topoSet.local.$i 2>&1
      echo "   refining cells..."
      cp system/refineMeshDict.local system/refineMeshDict
      refineMesh -dict -overwrite > log.refineMesh.local.$i 2>&1
      let i=i-1
   done
refineMeshGlobal()
   i=1
   while [ $i -le $1 ]
   do
      echo "Performing level $i global refinement"
      mpirun -np $(($nodes*$cores)) refineMesh -parallel -overwrite > log.refineMesh.global.$i 2>&1
      let i=i+1
   done
echo "Starting OpenFOAM job at: " $(date)
echo "using " $(($nodes*$cores)) " processors"
# Get a clean version of the intial fields
rm -rf 0
cp -rf 0.original 0
# Copy the proper controlDict into place
cp system/controlDict.1 system/controlDict
# Make the background coarse mesh using blockMesh (serial)
echo "Running blockMesh"
cp constant/polyMesh/blockMeshDict ./
rm -rf constant/polyMesh/*
mv ./blockMeshDict constant/polyMesh
blockMesh > log.blockMesh 2>&1
# Perform local refinement (serial)
refineMeshLocal 3
# Decompose the mesh and solution files (serial)
echo "Running decomposePar"
cp system/decomposeParDict.$(($nodes*$cores)) system/decomposeParDict
decomposePar -cellDist -force > log.decomposePar
# Perform global refinement to desired resolution (parallel)
refineMeshGlobal 1
# Check the mesh.
mpirun -np $(($nodes*$cores)) checkMesh -parallel > log.checkMesh 2>&1
# Run the solver (parallel)
mpirun -np $(($nodes*$cores)) $solver -parallel > log.1.$solver 2>&1
echo "Ending OpenFOAM job at: " $(date)
mohsen.boojari is offline   Reply With Quote
scripts
HronTurekFsi tutorial case using icoFsiElasticNonLinULSolidFoam MarcelK OpenFOAM Running, Solving & CFD 9 February 25, 2019 03:25
MapFields doesnt work in the "counterFlowFlame2D" tutorial case panachristos OpenFOAM Running, Solving & CFD 9 August 26, 2018 22:27
[waves2Foam] Problem running waves2Foam "waveFlume" tutorial case k.nomi OpenFOAM Community Contributions 6 April 8, 2016 10:56
error in biconic25-55run35 tutorial case immortality OpenFOAM Running, Solving & CFD 5 June 16, 2013 12:03
SRFSimpleFoam tutorial case blows up on laptop (but runs on desktop?) AHMeng OpenFOAM Running, Solving & CFD 1 April 27, 2012 09:34
