[Other] Problems Installing DensityBasedTurbo library on Foam-Extend 3.0
Old   February 18, 2016, 01:07
Default Problems Installing DensityBasedTurbo library on Foam-Extend 3.0
Kenny Lozes
klozes is on a distinguished road
I have been trying to install the DensityBasedTurbo Library to Foam-Extend 3.0 on Ubuntu 14.04 with no luck. I followed the guide on the wiki here: http://openfoamwiki.net/index.php/Ex...oam-extend_3.0
It did install fine with Foam-Extend 1.6. However, the dynamicRefine mesh tool does not seems to work on 1.6 but it does on 3.0 (damBreak tutorial runs on 3.0 but not 1.6).
here are some of the errors. the complete make.log is also attached
backwardDualDdtScheme/backwardDualDdtScheme.C:698:62: note: declarations in dependent base ‘Foam::fv::ddtScheme<Foam::Tensor<double> >’ are not found by unqualified lookup
backwardDualDdtScheme/backwardDualDdtScheme.C:698:62: note: use ‘this->fvcDdtPhiCoeff’ instead
backwardDualDdtScheme/backwardDualDdtScheme.C: In instantiation of ‘Foam::tmp<typename Foam::fv::ddtScheme<Type>::fluxFieldType> Foam::fv::backwardDualDdtScheme<Type>::fvcDdtPhiCorr(const volScalarField&, const volScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const fluxFieldType&) [with Type = Foam::Tensor<double>; typename Foam::fv::ddtScheme<Type>::fluxFieldType = Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::volScalarField = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>; Foam::fv::backwardDualDdtScheme<Type>::fluxFieldType = Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>]’:
backwardDualDdtScheme/backwardDualDdtSchemes.C:41:1:   required from here
backwardDualDdtScheme/backwardDualDdtScheme.C:762:69: error: ‘fvcDdtPhiCoeff’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
                 rDeltaT*fvcDdtPhiCoeff(U.oldTime(), phiAbs.oldTime())
and
         -lfiniteVolume     -lbasicThermophysicalModels     -lspecie     -lcompressibleTurbulenceModel     -lcompressibleRASModels     -lcompressibleLESModels     -L/home/kenny/foam/kenny-3.0/lib/linuxGccDPOpt     -lDensityBasedSolvers     -lGodunovFlux -lfoam -ldl   -lm -o /home/kenny/foam/kenny-3.0/applications/bin/linuxGccDPOpt/transonicSteadySRFFoam
/usr/bin/ld: cannot find -lDensityBasedSolvers
collect2: error: ld returned 1 exit status
make: *** [/home/kenny/foam/kenny-3.0/applications/bin/linuxGccDPOpt/transonicSteadySRFFoam] Error 1
g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-200 -I../godunovFlux     -I../timeStepping/localTimeStep     -I../transonicMRFDyMFoam     -I/home/kenny/foam/foam-extend-3.0/src/finiteVolume/lnInclude     -I/home/kenny/foam/foam-extend-3.0/src/thermophysicalModels/specie/lnInclude     -I/home/kenny/foam/foam-extend-3.0/src/thermophysicalModels/basic/lnInclude     -I/home/kenny/foam/foam-extend-3.0/src/turbulenceModels/compressible/turbulenceModel/lnInclude     -I/home/kenny/foam/foam-extend-3.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/kenny/foam/foam-extend-3.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/home/kenny/foam/foam-extend-3.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/kenny/foam/foam-extend-3.0/src/foam/lnInclude -I/home/kenny/foam/foam-extend-3.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/transonicUnsteadyMRFDyMFoam.o -L/home/kenny/foam/foam-extend-3.0/lib/linuxGccDPOpt \
         -lbasicThermophysicalModels     -lspecie     -lcompressibleTurbulenceModel     -lcompressibleRASModels     -lcompressibleLESModels     -lfiniteVolume     -lmeshTools     -ldynamicFvMesh     -ldynamicMesh     -L/home/kenny/foam/kenny-3.0/lib/linuxGccDPOpt     -lDensityBasedSolvers     -lGodunovFlux -lfoam -ldl   -lm -o /home/kenny/foam/kenny-3.0/applications/bin/linuxGccDPOpt/transonicUnsteadyMRFDyMFoam
The godunovFlux library compiles fine, but the rest do not.
Any help would be greatly appreciated!
klozes is offline   Reply With Quote
Old   February 18, 2016, 20:21
Kenny Lozes
Its seems that it was a compiler issue. I switched from gcc 4.8 back to 4.6 and it compiled fine!
Old   April 4, 2020, 18:01
Default Same issue
Andrei Cojocea
avc18 is on a distinguished road
I came across this post while trying to install DensityBasedTurbo on OF3.0extended. I encountered the same issue and I was wondering if you still remember, what precisely did you change to install the solver.
Thank you in advance.
avc18 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[foam-extend.org] Foam extend 3.1 rpmBuild error. Saideep OpenFOAM Installation 2 September 25, 2016 20:34
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
