[SOWFA] NREL SOWFA pisoFoamTurbine tutorial problem
Old   February 6, 2016, 05:41
Exclamation NREL SOWFA pisoFoamTurbine tutorial problem
Mohsen
mohsen.boojari is on a distinguished road
Hi guys,
I've compiled the SOWFA code Developed at NREL and now I want to run it's tutorial example . the case name is : NREL5MWRef.uniformFlow
but i just can't run it. i faced with some errors. has anybody become succeed to do that?
I attached the case file if someone wants to see.
thank you
mohsen.boojari is offline   Reply With Quote
Old   February 9, 2016, 09:43
gereksiz
clktp is on a distinguished road
Did you manage to compile it without any errors, which openFoam version you use because I couldn't compile it properly with OF 2.3.1.
If you attach the error file, maybe I can help. I used to use SOWFA, but unfortunately not the pisoFoamTurbine
clktp is offline   Reply With Quote
allrun, sowfa, turbine, tutorial
chtMultiRegionFoam: problem with the tutorial samiam1000 OpenFOAM 21 January 25, 2020 17:32
[SOWFA] pisoFoamTurbine solver contained in the SOWFA: SST Turbulence Model problems capisedano OpenFOAM Community Contributions 2 January 23, 2020 07:10
Problem with Tutorial "Constrained Optimal Shape Design of a Fixed Wing"" MarcF SU2 Shape Design 3 December 9, 2016 05:30
multiRegionHeater tutorial visualization problem Bufacchi OpenFOAM Running, Solving & CFD 3 September 18, 2015 10:20
Vessel tutorial problem hosseinhgf CFX 1 March 17, 2013 12:39
