[swak4Foam] Sinusoidal initial liquid free surface using funkySetFields
Old   January 28, 2016, 01:25
Default Sinusoidal initial liquid free surface using funkySetFields
hydraulist is on a distinguished road
My apologies for initially posting this question in Main CFD forum, which i could not redirect to OpenFoam forum.
I'm trying to have a sinusoidal initial liquid free surface in Sloshing tank problems. Presently i'm using setFields with boxToCell function to create a flat liquid surface. While checking for setting different initial free surface conditions, i came to know about swak4Foam application which i could install. I'm using OF2.3.1.
I could not understand what "constant-value surfaceField" is, produced by "surf" function, which is explained in "https://openfoamwiki.net/index.php/Contrib_funkySetFields"
I want to have an expression a*cos(k*x) ( where a-amplitude of wave, k-wave number, x-variable along the length of tank), for the liquid free surface at time=0.
Kindly help me to do this.
Thank you.
hydraulist is offline   Reply With Quote
Old   January 28, 2016, 02:58
Default Error message while trying with sine function
I tried with the following command line expression for a linear slope free surface which worked correctly.
funkySetFields -time 0 -field alpha.water -expression "faceAverage(fpos().y <= surf(0.2)*fpos().x+surf(0.5) ? surf(1.0) : surf(0.))"
But while trying with,
funkySetFields -time 0 -field alpha.water -expression "faceAverage(fpos().y <= surf(0.2)*sin(fpos().x) ? surf(1.0) : surf(0.))"
I'm getting the following error message,
Create time
fileName::stripInvalid() called for invalid fileName funkysetfieldsine~
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
Please correct me to have sinusoidal initial liquid surface.
I saw some old threads related to free surface, but the conversations were not complete.
Old   September 28, 2023, 07:25
Default File names with spaces
atafiroozi is on a distinguished road
you have a file with spaces in its name inside the directory and OpenFOAM commands do not run while those are existing.
it seems like in your case, there is a file named sth like "funkysetfieldsine~" but with spaces ofc...
In general, try to avoid including spaces while naming files in Linux. Use underscores or hyphens instead.
atafiroozi is offline   Reply With Quote
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 20:31
