[swak4Foam] swak4foam 0.3.2 installation problem on Ubuntu 15.04 with OpenFOAM 2.4.0
Old   January 6, 2016, 22:43
Default swak4foam 0.3.2 installation problem on Ubuntu 15.04 with OpenFOAM 2.4.0
bin xu
ptsxx is on a distinguished road
Hi,everyone!
I use ubuntu 15.04 with openfoam 2.4.0.when i tried to install swak4Foam, i met some problems.
No file 'swakConfiguration'. Python etc won't work. See README for details
Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems
Checking swak4Foam-version and generating file
中止: no repository found in '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam' (.hg not found)!
Swak version is 0.3.2
Bison is version 2.7.12-4996
Flex is version 2.5.39 (Minor version: 39)
OpenFOAM-version: Major 2 Minor 4 Patch 0 (-1 == x / 0)
No change to swak4FoamParsers/foamVersion4swak.H
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libgroovyBC.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libsimpleFunctionObjects.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libsimpleSearchableSurfaces.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libsimpleSwakFunctionObjects.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakTopoSources.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakSourceFields.so' is up to date.
Compiling swakFvOptions
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakFvOptions.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libgroovyStandardBCs.so' is up to date.
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration. Most people are fine without it
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakChemistryModelFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakFvcSchemesFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianCloudSourcesFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLocalCalculationsFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakMeshQualityFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakMeshWaveFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakRadiationModelFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakRandomFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakSurfacesAndSetsFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakThermoTurbFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakTransportTurbFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakVelocityFunctionPlugin.so' is up to date.
'/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakCoalCloudAdaptor.so' is up to date.
If you have your own function-plugins you can specify them using the SWAK_USER_PLUGINS environment variable and they would be compiled now. If you don't know what this means: don't bother. You propably don't need it
make[1]: Entering directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/calcNonUniformOffsetsForMapped'
make[1]: '/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/calcNonUniformOffsetsForMapped' is up to date.
make[1]: Leaving directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/calcNonUniformOffsetsForMapped'
make[1]: Entering directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/fieldReport'
make[1]: '/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/fieldReport' is up to date.
make[1]: Leaving directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/fieldReport'
make[1]: Entering directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkyDoCalc'
make[1]: '/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/funkyDoCalc' is up to date.
make[1]: Leaving directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkyDoCalc'
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration. Utility funkyPythonPostproc not compiled
make[1]: Entering directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkySetBoundaryField'
make[1]: '/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/funkySetBoundaryField' is up to date.
make[1]: Leaving directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkySetBoundaryField'
make[1]: Entering directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkySetFields'
make[1]: '/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/funkySetFields' is up to date.
make[1]: Leaving directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkySetFields'
make[1]: Entering directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkySetLagrangianField'
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt  	 -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/lagrangian/basic/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/lagrangian/intermediate/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/basic/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/radiation/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/SLGThermo/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/specie/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/properties/solidProperties/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/regionModels/surfaceFilmModels/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/regionModels/regionModel/lnInclude -I../../Libraries/swakLagrangianParser/lnInclude/ -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/xubin/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/funkySetLagrangianField.o -L/home/xubin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib \
     -lfiniteVolume 	-lmeshTools 	-llagrangian 	-L/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib 	-lswakLagrangianParser 	-lswak4FoamParsers -lOpenFOAM -ldl   -lm -o /home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/funkySetLagrangianField
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘Foam::patchInjectionBase::patchInjectionBase(Foam::polyMesh const&, Foam::word const&)’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘Foam::patchInjectionBase::patchInjectionBase(Foam::patchInjectionBase const&)’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so:对‘typeinfo for Foam::reactingCloud’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so:对‘typeinfo for Foam::kinematicCloud’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘Foam::kinematicCloud::typeName’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘Foam::kinematicCloud::kinematicCloud()’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so:对‘Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > >::typeName’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘typeinfo for Foam::patchInjectionBase’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘Foam::kinematicCloud::~kinematicCloud()’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so:对‘Foam::Cloud<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > >::typeName’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so:对‘typeinfo for Foam::reactingMultiphaseCloud’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘Foam::patchInjectionBase::setPositionAndCell(Foam::polyMesh const&, Foam::cachedRandom&, Foam::Vector<double>&, int&, int&, int&)’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘Foam::patchInjectionBase::updateMesh(Foam::polyMesh const&)’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so:对‘Foam::patchInjectionBase::~patchInjectionBase()’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so:对‘Foam::Cloud<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > >::typeName’未定义的引用
/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so:对‘typeinfo for Foam::thermoCloud’未定义的引用
collect2: error: ld returned 1 exit status
/home/xubin/OpenFOAM/OpenFOAM-2.4.0/wmake/Makefile:149: recipe for target '/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/funkySetLagrangianField' failed
make[1]: *** [/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/funkySetLagrangianField] Error 1
make[1]: Leaving directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkySetLagrangianField'
/home/xubin/OpenFOAM/OpenFOAM-2.4.0/wmake/MakefileApps:39: recipe for target 'funkySetLagrangianField' failed
make: *** [funkySetLagrangianField] Error 2
make[1]: Entering directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkyWarpMesh'
make[1]: '/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/funkyWarpMesh' is up to date.
make[1]: Leaving directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/funkyWarpMesh'
make[1]: Entering directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/replayTransientBC'
make[1]: '/home/xubin/OpenFOAM/xubin-2.4.0/platforms/linux64GccDPOpt/bin/replayTransientBC' is up to date.
make[1]: Leaving directory '/home/xubin/OpenFOAM/xubin-2.4.0/swak4Foam/Utilities/replayTransientBC'
make: Target 'application' not remade because of errors.
how can i fix these?
thanks a lot!
ptsxx is offline   Reply With Quote
Old   January 10, 2016, 18:48
Retired Super Moderator
Bruno Santos
Greetings ptsxx and welcome to the forum!
I'm having trouble reproducing this error that you are getting. A few questions:
  1. Which installation instructions did you follow for installing OpenFOAM 2.4.0?
  2. Do you have more than one OpenFOAM or foam-extend version installed?
Best regards,
Bruno
[OpenFOAM.org] Ubuntu 14.04 LTS OpenFoam 4.1 Installation Error behzad-cfd OpenFOAM Installation 2 March 5, 2017 03:44
[OpenFOAM.org] OpenFoam 3.0 installation on Ubuntu 14.04.3 tab2001ng OpenFOAM Installation 3 March 8, 2016 02:38
[OpenFOAM.org] OpenFOAM 2.4.x installation script for ubuntu p0kerus OpenFOAM Installation 0 June 1, 2015 16:52
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 Nait OpenFOAM Installation 2 December 12, 2012 11:20
Installation problem: openfoam 2.1.0 on opensuse 11.4 raphael7 OpenFOAM Installation 4 April 12, 2012 08:10
