[SOWFA] pisoFoamTurbine solver contained in the SOWFA: SST Turbulence Model problems
Old   January 2, 2016, 20:47
Default pisoFoamTurbine solver contained in the SOWFA: SST Turbulence Model problems
capisedano is on a distinguished road
I have been using the pisoFoamTurbine solver contained in the SOWFA software (https://github.com/NREL/SOWFA). I'm using the SST turbulence model. To do so, I have included U, p, k and omega sub-directories as initial conditions for the case. However when when I run pisoFoamTurbine, it shows the following error:
Reading field, p...
Reading field, U...
Creating vorticity field, omega...
--> FOAM FATAL IO ERROR:
unexpected class name volScalarrField expected volVectorField
while reading object omega
file: /home/camilosedano/OpenFOAM/camilosedano-2.3.1/Turb/1_Turbina/0.25M/0/omega at line 15.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 136.
FOAM exiting
To solve it, I change the class of the "omega" file from volScalarField to volVectorField, and change the values from scalar to vector notation. When I run the solver again it shows the same error, but this time it states that it should read a volScalarField (as it used to be) instead of a volVectorField.
I have been looking at the solver code to see if I can find anything that leads to this error but I haven't found anything. I'm new to OpenFOAM so thanks for any help you can give me.
Thank you,
Camilo.
capisedano is offline   Reply With Quote
Old   December 3, 2019, 06:13
Default same problem
Armin Alavi
ArminAlavi is on a distinguished road
hello
same problem here.
have worked yours out? I would appreciate it if you help me solve mine.
ArminAlavi is offline   Reply With Quote
Old   January 23, 2020, 07:10
Rachael Smith
rs495 is on a distinguished road
I had the same issue, the problem is that the pisoFoamTurbine solvers create a vector field for vorticity that is also called omega, so there is a clash when you use kOmega or kOmega SST.
The problem can be avoided if you change the name of the vorticity field in the pisoFoamTurbine solvers to something other than omega and then recompile - hope this works for you!
rs495 is offline   Reply With Quote
openfoam, turbulence modeling
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Y+ value for SST turbulence model beyonder1 CFX 5 January 7, 2016 19:30
SST turbulence model question in ANSYS CFX drsidd10 CFX 2 January 18, 2015 06:38
Transitional Flow Shear Stress Transport (SST) k-omega Turbulence Model josechen FLUENT 0 July 20, 2011 17:06
Stalling residuals in kw SST turbulence model jorllam CFX 3 February 13, 2007 16:51
