[swak4Foam] how does install swak4foam with OpenFOAM 3.0? |
December 11, 2015, 05:52 |
#21 |
Shahabeddin
Rep Power: 11 |
Hi Bruno
I used Official OpenFoam website's instruction to install OF3.0. but downloaded the deb pack separately and then tried to install it. during installation I used a proxy server since sorceforge wasn't accessible from my location. 2. No modification has been applied. 3.the command gives: Code:
ldd $(which blockMesh) linux-gate.so.1 => (0xb7782000) libblockMesh.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libblockMesh.so (0xb773b000) libmeshTools.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libmeshTools.so (0xb73c0000) libdynamicMesh.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libdynamicMesh.so (0xb7060000) libOpenFOAM.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so (0xb6927000) libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb690a000) libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb6792000) libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb6745000) libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb6727000) libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb656c000) libtriSurface.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libtriSurface.so (0xb64df000) libsurfMesh.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libsurfMesh.so (0xb63e9000) libfileFormats.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libfileFormats.so (0xb6364000) libfiniteVolume.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libfiniteVolume.so (0xb5014000) libextrudeModel.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libextrudeModel.so (0xb4ffa000) libPstream.so => /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/openmpi-system/libPstream.so (0xb4fec000) libz.so.1 => /lib/i386-linux-gnu/libz.so.1 (0xb4fd0000) /lib/ld-linux.so.2 (0x80086000) libmpi.so.1 => /usr/lib/libmpi.so.1 (0xb4e36000) libhwloc.so.5 => /usr/lib/i386-linux-gnu/libhwloc.so.5 (0xb4df3000) libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb4dd6000) libutil.so.1 => /lib/i386-linux-gnu/libutil.so.1 (0xb4dd1000) libltdl.so.7 => /usr/lib/i386-linux-gnu/libltdl.so.7 (0xb4dc5000) libnuma.so.1 => /usr/lib/i386-linux-gnu/libnuma.so.1 (0xb4db8000) 4. And this one gives: Code:
ls -l $FOAM_LIBBIN/$FOAM_MPI total 128 -rw-r--r-- 1 root root 60933 نوامب 1 22:33 libPstream.so -rw-r--r-- 1 root root 69513 نوامب 1 22:47 libptscotchDecomp.so 5.the last command results: Code:
md5sum $FOAM_LIBBIN/$FOAM_MPI/* 147a90c44c02f769bf5a37126d91496b /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/openmpi-system/libPstream.so 131a1a948b477403c25540b56f821141 /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/openmpi-system/libptscotchDecomp.so |
December 11, 2015, 08:18 |
#22 |
Shahabeddin
Rep Power: 11 |
one other question Mr.Bruno as you said you tested the swak4Foam on Ubuntu 15.10 and OF3.0, and maybe some files are missing during OF installation on my computer. So, is there any way to remove all footprints of installing OpenFoam and then install it again? or its better install the Ubuntu again and then go for OpenFoam installtion? Or both these ways are not helpful? and the problem can be resolved without any reinstallation. I have another computer which is running Ubuntu 14.04 and OpenFoam 2.4.0 I installed swak4Foam on it and its working But it cannot perform the blockMesh. Thanks and regards Shahabeddin |
December 12, 2015, 16:22 |
#23 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Shahabeddin,
5bb6c6a192b8d806d02c2c92504d9aa5 /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/openmpi-system/libPstream.so 6c5c581b8afe3032ec4567a500d24343 /opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/openmpi-system/libptscotchDecomp.so Code:
md5sum *.deb Code:
9a42d626a64a233d2d338700d19aed78 Best regards, Bruno Last edited by wyldckat; December 12, 2015 at 16:23. Reason: added reference to the package name |
December 20, 2015, 00:57 |
#24 |
Shahabeddin
Rep Power: 11 |
Dear Bruno
As per your instruction I reinstalled the OpenFOAM and the swak4Foam is installed without problem at first look. Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // swakVersion: 0.4.0 (Release date: Next release) // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Thank you for helping me step by step. Regards Shahabeddin |
December 29, 2015, 08:49 |
#25 |
Milad Setareh
Rep Power: 14 |
Dear wyldckat
I install swak4foam: swak4Foam development version for OpenFOAM 2.x/3.x/dev and foam-extend 3.x I think my problem is solved. thank you for your help. |
[OpenFOAM.org] Install OpenFOAM 2.4.x using system Scotch | cbcoutinho | OpenFOAM Installation | 7 | October 16, 2019 20:12 |
[swak4Foam] swak4Foam and OpenFoam 3.0.x | fs82 | OpenFOAM Community Contributions | 38 | September 10, 2018 18:44 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 04:18 |
[swak4Foam] Basic Error when installing swak4foam with foam extend 3.0 | mnobrega | OpenFOAM Community Contributions | 6 | April 1, 2014 02:47 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 12:32 |
