[Other] Difficulties trying to install porousMultiphaseFoam on OpenFOAM for Windows 15.06 |
September 15, 2015, 10:36 |
Jeroen Koeleman
Rep Power: 12 |
I’ve tried to install the porousMultiphaseFoam toolbox (https://github.com/phorgue/porousMultiphaseFoam.git) on the OpenFoam for windows15.06, but I can’t get it to work. Below are the instructions provided with the toolbox: * Installation instructions : - First, source the OpenFOAM configuration file, i.e. (example for ubuntu version) : source /opt/openfoam2xx/etc/bashrc - then in the "porousMultiphaseFoam" directory, run : ./Allwmake to install the package. - Dynamic libraries, "libporousBoundaryConditions.so" and "libporousModels.so" are compiled in the standard OpenFOAM user directory : $FOAM_USER_LIBBIN; - The executable solver "impesFoam" is placed in the standard OpenFOAM user directory $FOAM_USER_APPBIN. - Each tutorial directory contains "run" and "clean" files to test installation and validate the solver. - To remove temporary files AND dynamic librairies AND executables, run : ./Allwclean Below are the steps I’ve taken. 1.Copy the complete porousMultiphaseFoam folder to C:\OpenFOAM\cygwin64\opt\OpenFOAM\OpenFOAM-2.3.x\tutorials\ 2.Start Openfoam for windows 15.06 by clicking on the icon 3.Type the following command: source /opt/OpenFOAM/OpenFOAM-2.3.x/etc/bashrc 4.Change directory to opt/OpenFOAM/OpenFOAM-2.3.x/tutorials/multiphase/porousMultiphaseFoam 5.Run command: ./Allwmake This gives me the following error on the bottom of the command output: capillarityModels/BrooksAndCorey/pcBrooksAndCorey.dep:414: recipe for target 'Make/cygwin64mingw-w64DPOpt/pcBrooksAndCorey.o' failed make: *** [Make/cygwin64mingw-w64DPOpt/pcBrooksAndCorey.o] Error 1 + wmake impesFoam Making dependency files... x86_64-w64-mingw32-g++ -m64 -Dcygwin64 -DWM_DP -DMSWIN -DLITTLE_ENDIAN -Wall -Wextra -Wno-unused-parameter -Wnon-virtual-dtor -O3 -DNDEBUG -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../porousModels/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/MSWindows/lnInclude -Wl,--enable-auto-import,--enable-auto-image-base,--force-exe-suffix,--strip-all Make/cygwin64mingw-w64DPOpt/impesFoam.o -L/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/lib \ -lfiniteVolume -L/home/j.koeleman/OpenFOAM/j.koeleman-2.3.x/platforms/cygwin64mingw-w64DPOpt/lib -lporousBoundaryConditions -lporousModels -lOpenFOAM -lm -o /home/j.koeleman/OpenFOAM/j.koeleman-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/impesFoam.exe /usr/lib/gcc/x86_64-w64-mingw32/4.8.3/../../../../x86_64-w64-mingw32/bin/ld: cannot find -lporousModels collect2: error: ld returned 1 exit status /opt/OpenFOAM/OpenFOAM-2.3.x/wmake/Makefile:155: recipe for target '/home/j.koeleman/OpenFOAM/j.koeleman-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/impesFoam.exe' failed make: *** [/home/j.koeleman/OpenFOAM/j.koeleman-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/impesFoam.exe] Error 1 + wmake anisoImpesFoam Making dependency files... x86_64-w64-mingw32-g++ -m64 -Dcygwin64 -DWM_DP -DMSWIN -DLITTLE_ENDIAN -Wall -Wextra -Wno-unused-parameter -Wnon-virtual-dtor -O3 -DNDEBUG -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I../porousModels/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/MSWindows/lnInclude -Wl,--enable-auto-import,--enable-auto-image-base,--force-exe-suffix,--strip-all Make/cygwin64mingw-w64DPOpt/anisoImpesFoam.o -L/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/lib \ -lfiniteVolume -L/home/j.koeleman/OpenFOAM/j.koeleman-2.3.x/platforms/cygwin64mingw-w64DPOpt/lib -lporousBoundaryConditions -lporousModels -lOpenFOAM -lm -o /home/j.koeleman/OpenFOAM/j.koeleman-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/anisoImpesFoam.exe /usr/lib/gcc/x86_64-w64-mingw32/4.8.3/../../../../x86_64-w64-mingw32/bin/ld: cannot find -lporousModels collect2: error: ld returned 1 exit status /opt/OpenFOAM/OpenFOAM-2.3.x/wmake/Makefile:155: recipe for target '/home/j.koeleman/OpenFOAM/j.koeleman-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/anisoImpesFoam.exe' failed make: *** [/home/j.koeleman/OpenFOAM/j.koeleman-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/anisoImpesFoam.exe] Error 1 After I've copied the tutorial folder to my $FOAM_RUN folder I’ve ran the ./run command. In the impes.log file I find the following line: /opt/OpenFOAM/OpenFOAM-2.3.x/bin/tools/RunFunctions: line52 impesFoam: command not found. Blockmesh and setfields does work. Can Anyone help me to get this working? Thank you! With kind regards, Jeroen Last edited by JKoeleman; September 15, 2015 at 15:19. |
Combustion modelling in OpenFOAM - Difficulties | AleDR | OpenFOAM Running, Solving & CFD | 23 | January 31, 2021 00:40 |
[OpenFOAM.com] Docker OpenFOAM install error on Mac OS X | dersh | OpenFOAM Installation | 10 | May 6, 2016 13:49 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 04:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
Install openFOAM from with proxy server | Dhruval | OpenFOAM Installation | 3 | October 18, 2014 16:38 |
