[swak4Foam] Compiling the swak4Foam for OpenFOAM-dev
Old   August 17, 2015, 12:00
Default Compiling the swak4Foam for OpenFOAM-dev
Ehsan
ehsan_madadi is on a distinguished road
Dear all,
I wanted to use the swak4Foam with the current -dev version of the OpenFOAM, but when I want to compile it, it comes back with this error message:
./Allwmake
This is a clean install
/home/ehsan/OpenFOAM/ehsan-dev/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
swakConfiguration: line 1: python-config: command not found
swakConfiguration: line 2: python-config: command not found
swakConfiguration: line 13: [: : integer expression expected
Checking swak4Foam-version and generating file
Swak version is 0.3.2
Bison is version 2.7.12-4996
Flex is version 2.5.37 (Minor version: 37)
OpenFOAM-version: Major  Minor dev Patch dev (-1 == x / dev)
No swak4FoamParsers/foamVersion4swak.H. Generated
wmakeLnInclude: linking include files to simpleFunctionObjects/lnInclude
make: *** No rule to make target 'Make/linux64GccDPInt32Opt/SubsetValueExpressionParser.o', needed by 'Make/linux64GccDPInt32Opt/CellSetValueExpressionDriver.o'.  Stop.
wmake error: file 'Make/linux64GccDPInt32Opt/sourceFiles' could not be created in /home/ehsan/OpenFOAM/ehsan-dev/swak4Foam/Libraries/swak4FoamParsers
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
I downloaded it from the main website http://openfoamwiki.net/index.php/Co...am#Downloading, and it compiles and works fine with OpenFOAM-2.4.x, however I could not succeed in making it work for -dev version. I need it to do volume averaging for an internalField. I appreciate in advance for any help and suggestion about this problem or any suggestion for better way to do the volume averaging.
I am using OpenSuse 13.2 btw.
Best regards,
Ehsan
ehsan_madadi is offline   Reply With Quote
Old   August 17, 2015, 12:59
Retired Super Moderator
Bruno Santos
Quick answer: https://twitter.com/swakPyFoam/statu...42774468964352
Development repository of #swak4foam now supports OpenFOAM-dev. Changes for that port happen in branch feature/port_of-dev
Development repository of #swak4foam ==> mercurial repository for swak4Foam.
Old   August 17, 2015, 14:01
Ehsan
Hi Bruno,
Thank you for your quick and very useful answer. I appreciate for it. I try it and if I faced a problem, I will ask your kind help again. Have a great time.
Best regards,
Ehsan
swak4foam, swak4foam error, volume averaging
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 12:59
source term in near wall cell rajcfd OpenFOAM Pre-Processing 5 February 1, 2016 11:31
[swak4Foam] compiling swak4foam on an IBM Dataplex running 64-bit RedHat 6.3 jianni OpenFOAM Community Contributions 22 January 5, 2014 17:49
[swak4Foam] Problem with compiling swak4Foam The_Architect OpenFOAM Community Contributions 4 September 11, 2013 07:24
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 14:00
