[swak4Foam] expressionField + execFlowFunctionObjects + AMI |
July 16, 2015, 02:09 |
Pete Bachant
Rep Power: 14 |
I am having trouble using swak4Foam expressionFields for post-processing a case with a sliding mesh AMI (OF 2.4.x). I am getting these results:
Create time Create mesh for time = 0 Reading U Reading p Creating expression field gradP ...swak4Foam: Allocating new repository for sampledMeshes swak4Foam: Allocating new repository for sampledGlobalVariables AMI: Creating addressing and weights between 278 source faces and 282 target faces AMI: Patch source sum(weights) min/max/average = 0.9999995653, 1.000053043, 1.000021541 AMI: Patch target sum(weights) min/max/average = 0.9999988541, 1.000055873, 1.000021313 type:volVectorField Creating expression field gradUx ... type:volVectorField Creating expression field laplacianUx ... type:volScalarField Time = 0 Reading phi --> FOAM Warning : --> FOAM FATAL IO ERROR: cannot find file file: /home/pete/OpenFOAM/pete-2.4.x/run/unh-rvat-2d/0/phi at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. Time = 0.02 --> FOAM FATAL ERROR: Field U does not exist From function Foam::readAndUpdateFields::read(const dictionary& dict) in file misc/readAndUpdateFields/readAndUpdateFields.C at line 128. FOAM exiting |
Cyclic AMI patch minimum weight goes to zero | muhammss | OpenFOAM Running, Solving & CFD | 16 | October 7, 2022 05:26 |
Translating and Rotating AMI | HiddenSquid | OpenFOAM Pre-Processing | 1 | October 25, 2017 04:59 |
Help compiling code (newbie) | thsb20 | OpenFOAM Programming & Development | 56 | August 24, 2016 05:24 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
