[swak4Foam] run-time function/expression evaluation at a part of a cross section
Old   July 1, 2015, 11:17
Question run-time function/expression evaluation at a part of a cross section
Silvan
silvan is on a distinguished road
Dear foamers,
I am trying to calculate the mass flow (and other quantities) during run-time with functions/expressions from swak4foam. So far, I successfully managed to compute these values at a randomly defined plane which slices the complete domain. Now, I would like to calculate these values at a part/subset of this cross section, e.g. a circle which lies in this plane.
Here is a short description on how I am trying to achieve this:
1) Use topoSet to define a sphere with the desired radius. Create a zone of the cells within this sphere.
2) Use functions in the controlDict to define the plane of interest and calculate whatever needed. Using zone, I expect to "intersect" the sphere with the plane and thus create the desired circle.
The only thing that I was able to achieve was that the plane I am looking at has been reduced to about half its original size (looks kind of random in ParaView). Thus, also the calculated mass flow has reduced accordingly. BUT, the mass flow is still computed on the whole of the remaining plane. So, no sign of successful "intersection"...
I already searched the internet and found the following resources:
http://openfoamwiki.net/index.php/TopoSet
https://github.com/OpenFOAM/OpenFOAM...et/topoSetDict
http://www.cfd-online.com/Forums/ope...ing-plane.html
http://openfoamwiki.net/images/2/2a/...esentation.pdf
But, none of these could answer my question completely...
And here follows a code snippet of the topoSetDict:
actions
    name        apertureSphereZone;
    type        cellSet;
    action      new;
    source      sphereToCell;
    sourceInfo
        centre  (-1 0 0);
        radius  0.18;
    type        cellZoneSet;
    action      new;
    source      setToCellZone;
    sourceInfo
        set     apertureSphereZone;
And a snippet from the controlDict with the functions:
libs (
    "libgroovyBC.so"
    "libsimpleFunctionObjects.so"
    "libsimpleSwakFunctionObjects.so"
    "libswakFunctionObjects.so"
    "libgroovyStandardBCs.so"
functions
flowAperture
    type        swakExpression;
    valueType   surface;
    surfaceName aperturePlane;
    surface
        type            plane;
        basePoint       (-1 0 0);
        normalVector    (1 0 0);
        interpolate     true;
        zone            apertureSphereZone;
    expression  "U.x*rho";
    writeSurfaceOnConstruction true;
    surfaceFormat       vtk;
    accumulations
        min
        max
        weightedAverage
        integrate
    outputControlMode   timeStep;
    outputInterval      1;
    verbose             true;
I ask you the following:
A) Am I on the right track?
B) Are there alternatives? Could one use e.g.
condition "(pow(pos().y,2)+pow(pos().z,2)) < pow(0.18,2)";
within the swakExpression to achieve the same?
Every hint will be appreciated! Thanks in advance for your support!
Happy foaming to you all,
Silvan
silvan is offline   Reply With Quote
Old   July 3, 2015, 04:53
Post I am still looking for your opinion :-)
Silvan
I am still stuck with this question and would highly appreciate your opinion on this matter.
Especially comments from gschaider are welcomed. By the way, thank you very much for developing these useful tools! :-)
Looking forward to your inspirations!
Silvan
Old   July 13, 2015, 03:31
Default No solution so far...
Silvan
Dear Foamers,
I didn't come any further...
Is it true that no one has a suggestion on how to solve this??? In such a big group of experts?
Looking forward to your reply,
Silvan
Old   August 3, 2015, 11:12
RMF
RMF is on a distinguished road
I have the same problem!
@gschaider any suggestions?
RMF
RMF is offline   Reply With Quote
expression, function, run-time processing, swak4foam, toposet
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
Transient run continues from last time (when startover is desired) bongbang CFX 2 March 23, 2015 00:05
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
