[cfMesh] How can i get the proper result by cfMesh and icoFoam |
May 17, 2015, 15:45 |
Choi Hak Kyu
Rep Power: 11 |
I made a mesh by cfMesh, like attached picture. and then solve this case by icoFoam initial conditon is v=0.1m/s but, you can see there is non-physical result on the mesh grading region. so, how can i get proper result in this case? this is my fvSolution, fvSchemes file. thank you Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; } divSchemes { default Gauss upwind; div(phi,U) Gauss linearUpwindV Gauss linear; div((nuEff*dev(grad(U).T()))) Gauss linear; } laplacianSchemes { default Gauss linear orthogonal; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-7; relTol 0; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; /* solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; */ } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0; nSweeps 1; /* solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0; */ } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } relaxationFactors { p 0.3; U 0.7; k 0.7; epsilon 0.7; omega 0.7; } // ************************************************************************* // |
May 18, 2015, 07:24 |
What happens when you replace linearUpwindV or the momentum equation with vanLeer, Gamma or limitedLinear? In addition, what happens when you increase the number of sweeps in solver? Regards, Franjo
Principal Developer of cfMesh and CF-MESH+ www.cfmesh.com Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram |
