[ImmersedBoundary] foam-extend 3.1, Immersed boundary cavity flow case modification problems |
Anamitra Bagchi
Rep Power: 11 ![]() |
Hello
I have been trying to modify a cavity case as follows in openfoam 3.1 ext, Immersed boundary package. 1) I follow all the ./All run steps from cavity flow around a cylinder 2) I changed the cylinder geometry with a square (cube), made some necessary changes in the other files as well. 3) blockMesh runs prefectly fine. 4) Then I copy the Immersed boundary 'boundary' file (with the dimensions of square as it is done) into constant/polymesh 5) I run icoIbFoam, which runs perfectly 6) My problem: in the paraview I dont see my immersed boundary square.!! Can someone help me set up a case with the Immersed boundary, please !! Thank you !! |
cavity problem, immersed boundary, openfoam 3.1 ext |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
