[swak4Foam] groovy bc, conditioned valueExpression.
Old   March 16, 2015, 04:48
Default groovy bc, conditioned valueExpression.
Kan
nwpukaka is on a distinguished road
Dear OpenFOAMer,
I am currently using groovyBC to set my thermal boundary condition, the flow regime is determined based on Reynolds number Re, which is calculated in the "variables", and three different heat transfer coefficients ( hf0, hf1, hf2 ) corresponding to laminar, transition and turbulent are also calculated with "variables". The condition is something like
if ( Re< 2000 ) hf0;
else if ( Re > 4000 ) hf2;
else hf1;
However, I am not sure how to set the expression in valueExpression session.
Here is the example I found:
valueExpression "(pos().z<=A*cos(-w*time())+0.5*k*A*A*cos(2*(-w*time()))) ? 1 : 0";
It only has two conditions, but 3 conditions in my case, can anybody show me how to do that?
Cheers,
Kan
nwpukaka is offline   Reply With Quote
Old   March 16, 2015, 09:47
Joachim Herb
jherb is on a distinguished road
You could try something like
valueExpression "Re <= 2000 ? hf0 : (Re <= 4000 ? hf1 : hf2)";
But you still need to find a way to calculate Re and hf1/2/3.
jherb is offline   Reply With Quote
Old   March 16, 2015, 18:30
Kan
Thank you, Joachim, this really helps!
Cheers,
Kan
[swak4Foam] Engine-pressure BC and velocity field (groovy) Tobi OpenFOAM Community Contributions 3 October 15, 2018 15:09
[swak4Foam] groovy BC imani OpenFOAM Community Contributions 1 April 13, 2014 08:43
[swak4Foam] groovy BC Ahmed Khattab OpenFOAM Community Contributions 4 November 7, 2013 08:51
[swak4Foam] groovyBC: using gradientExpression instead of valueExpression gregdB OpenFOAM Community Contributions 15 September 20, 2013 09:03
[swak4Foam] Setting BC for a passive scalar (groovy vs fvOptions) Tobi OpenFOAM Community Contributions 0 May 23, 2013 15:53
