[swak4Foam] InterFoam + FunkySetFields - Initial phase function of the given volume
Old   February 12, 2015, 19:03
Default InterFoam + FunkySetFields - Initial phase function of the given volume
Pedro
pedrojrebelo is on a distinguished road
I have a multiphase simulation with interFoam. As an initial condition for the phase what I would like to do is to set a volume of liquid. For instance in the case of a cylinder of 1L (easy one because we can compute the volume analytically) I would like to set the initial field with 0.5L. I would like to make this work for more complex geometries...
I guess this should be possible with funkySetFields, by computing the total volume and start filling each cell until it reaches the desired volume. Does someone has any further suggestion?
Regards
pedrojrebelo is offline   Reply With Quote
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
