[swak4Foam] Difference between snGrad(U) using swakExpression and wallgradU utility ?
Old   December 16, 2014, 23:52
Question Difference between snGrad(U) using swakExpression and wallgradU utility ?
Daniel
Dan1788 is on a distinguished road
I am doing an LES of pipe flow. The streamwise direction is the z-direction. In my controlDict I enter the following "swakExpression" to keep track of my wall shear stress:
wallShear
        type    swakExpression;
        valueType   patch;
        patchName   Side;
        accumulations   (
            average
        expression  "nu*1.16*snGrad(U)";
        verbose true;
The output of the following in my "postProcessing" folder is as follows:
      Time
      1.15            (0.00158395 -0.00195003 -0.309623)
      1.15001            (0.0015569 -0.0018457 -0.31036)
      1.15002            (0.00154682 -0.00179581 -0.310094)
      1.15002            (0.0015546 -0.00176741 -0.30988)
      1.15003            (0.0015752 -0.00177392 -0.309709)
      1.15003            (0.00154428 -0.00172741 -0.309567)
      1.15004            (0.00152869 -0.00170179 -0.309448)
      1.15004            (0.00154396 -0.00171494 -0.309346)
      1.15005            (0.00153824 -0.00171052 -0.309258)
      1.15005            (0.00153934 -0.00171405 -0.309179)
      1.15006            (0.00153327 -0.00170792 -0.30911)
      1.15006            (0.00152485 -0.00169658 -0.309047)
      1.15007            (0.00152928 -0.00169544 -0.308991)
      1.15007            (0.00153558 -0.00170495 -0.30894)
      1.15008            (0.00153235 -0.00170306 -0.308893)
      1.15008            (0.00153008 -0.00169775 -0.308849)
      1.15009            (0.00154298 -0.00171269 -0.30881)
      1.15009            (0.00154351 -0.00171235 -0.308773)
       1.1501            (0.00153823 -0.00170273 -0.308739)
       1.1501            (0.00153198 -0.00169867 -0.308707)
      1.15011            (0.00152493 -0.00169242 -0.308677)
      1.15011            (0.00153547 -0.00170078 -0.30865)
      1.15012            (0.00153531 -0.00170344 -0.308624)
      1.15012            (0.00152695 -0.00169185 -0.3086)
      1.15013            (0.00152394 -0.00168702 -0.308578)
      1.15013            (0.00152902 -0.00170066 -0.308557)
      1.15014            (0.00152878 -0.00170005 -0.308537)
You see that the tau_w(z-direction) is always in the range of ~ 0.3.
However when I compute the wall shear stress using the wallShearStressLES utility, the output is as follows:
(0.00922472 -0.00948885 -0.436616)
(0.0167652 -0.0139423 -0.497059)
(0.027834 -0.0217006 -0.573286)
(0.0405144 -0.0274527 -0.648546)
(0.0479752 -0.029261 -0.717811)
(0.0462766 -0.0244107 -0.7791)
(0.0379119 -0.0177215 -0.833495)
(0.0251241 -0.010028 -0.885577)
(0.0158647 -0.00529415 -0.91607)
(-0.00224175 0.000942265 -0.846752)
(-0.0139847 0.0031963 -0.695487)
(-0.0133073 0.00202354 -0.506113)
(0.00138907 -0.000239348 -0.352859)
(-0.00568237 0.000631173 -0.211232)
(-0.0198709 0.000730177 -0.169419)
(-0.00914825 -0.00054803 -0.258058)
(0.0156156 0.00114809 -0.448939)
(0.00519621 0.0010823 -0.597595)
(0.00899102 0.00132361 -0.671042)
(0.0455127 0.0108841 -0.716581)
(0.0519395 0.0163323 -0.705576)
(0.0428748 0.0163925 -0.644185)
(0.0271054 0.0124011 -0.564419)
(0.0127216 0.00706786 -0.551247)
(0.00512223 0.00361148 -0.617746)
(0.00279277 0.00222053 -0.690317)
(0.00107463 0.0039771 -0.730843)
(0.00670205 0.00761867 -0.778388)
(0.0236784 0.0209093 -0.886947)
(0.0405041 0.0391589 -1.10094)
(0.011279 -0.0109334 -0.438007)
(0.0185427 -0.0161606 -0.500274)
(0.0297334 -0.0231098 -0.57867)
(0.0411742 -0.0284098 -0.654419)
(0.0476158 -0.029062 -0.72111)
(0.0457186 -0.0245445 -0.77872)
(0.0385896 -0.018128 -0.830116)
(0.0269545 -0.0107781 -0.883763)
(0.0166884 -0.00548417 -0.914038)
(-0.00277345 0.00124665 -0.838704)
(-0.0161723 0.00388169 -0.685918)
(-0.0180005 0.00293102 -0.501037)
(3.30381e-05 -1.50492e-05 -0.35243)
(-0.00945636 0.00110753 -0.208022)
(-0.0277763 0.000992707 -0.172966)
(-0.0160046 -0.000732155 -0.269808)
(0.00941981 0.000497363 -0.453516)
(0.00323716 0.000629968 -0.600543)
(0.0046372 0.000533136 -0.683728)
Clearly the values of the z-component here are really far apart.
Which one is correct and what is the difference between both using snGrad(U) in the first approach and then using the wallShearStressLES utility ??
Please help
Dan1788 is offline   Reply With Quote
Old   December 17, 2014, 22:26
Daniel
Can anyone help please?
Old   December 18, 2014, 05:40
Assistant Moderator
Bernhard Gschaider
wallShear
        valueType   patch;
        patchName   Side;
        accumulations   (
            average
        verbose true;
      Time
Please help
Depends on your definition of "correct". I think the names are pretty self-explanatory: snGrad(U) in swak ONLY looks at the velocity field and calculates the gradient. wallShearStressLES (as the name says) adds the effect of the turbulence model. I'd only see a problem if wallGradU (which you mention in the title) differs significantly from swak
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 21, 2014, 18:21
Default Test between nu*rho*snGrad(U) and nu*rho*wallGrad(U)
Daniel
Hi Bernhard,
Thanks for your reply.
So I did a small test to compare results of the wall Shear stress using snGrad(U) and using wallGrad(U) utility.
Following are a couple of lines as output from wallGrad(U) -latestTime
(158.301 -63.0679 9752.01)
(-18.023 -183.104 9801.31)
(70.9486 -45.88 9654.49)
(119.605 -84.467 9432.72)
(138.58 -85.0173 9607.43)
(138.097 -74.9961 10680.3)
(240.245 -116.391 12213)
(439.328 -183.63 12451.1)
(545.342 -192.911 11860.8)
(507.157 -148.288 10896.3)
(177.236 -40.1328 9856.27)
(-232.057 45.4857 10258.2)
If I look at the 3rd collumn and multiply that by nu*rho (1.53e-05*1.16), the values I get are really off from the output of nu*rho*snGrad(U). The nu*rho*snGrad(U) from the swakExpresssion looks like this:
Time
Clearly there is a huge difference between the output of wallGrad(U) and snGrad(U) and I dont know why Please help me understand this. Thanks
Old   January 7, 2015, 16:50
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Time
And it doesn't confuse you that wallGrad(U) produces widly varying results?
You are comparing an averaged value at different times (swak) with the raw data at one timestep (wallGrad(U), snGrad(U)) Of course they differ. But if you average the wallShearStressLES-output you should get similar values to swak
BTW: if your patch has faces of different sizhes you'll probably want to use weightedAverage as the accumulation
