[flameletFoam] flameletFoam (by Hagen Müller)
Like Tree27Likes
Old   April 2, 2016, 10:58
Question 2.3.1 - Problems installing FlameletFOAM
  #21
[NF] is on a distinguished road
I hope I started my Thread in the right Subsection.
To my Problem:
I'm new to OpenFOAM. In order to use OpenFOAM with the Flameletmodel, I wanted to install FlameletFOAM. Therefore I followed this instructions: http://openfoamwiki.net/index.php/Ex...n/flameletFoam
Due to the Fact, that openFOAM 2.3.0 wasn't availible via "sudo apt-get install openfoam230", I installed OpenFOAM 2.3.1.
I followed the instruction and installed cantera 2.0.0.
In the Step of Installing the counter-flow diffusion flame solver I got a problem:
When I was typing "make" to my terminal, I get an error:
nf@NF-VPC:~/cantera-2.0.0/Cantera-CounterflowFlame/src$ make
g++  flamelet.o StFlow_2.o TransportFactory_2.o Lewis1Transport.o -lf2c -pthread -L/opt/cantera/lib -lcantera -lctmath -lexecstream -lsundials_cvodes -lsundials_ida -lsundials_nvecserial -L/opt/cantera/lib -lctlapack -lctblas  -lctf2c  -lblas -llapack  -o flamelet
/usr/bin/ld: cannot find -lf2c
/usr/bin/ld: cannot find -lctlapack
/usr/bin/ld: cannot find -lctblas
collect2: error: ld returned 1 exit status
make: *** [flamelet] Fehler 1
Because of this error, there is also no executable flamelet file in the main folder.
Could you please help me?
Thanks a lot
Last edited by wyldckat; April 2, 2016 at 11:57. Reason: (moved from the "OpenFOAM Installation" forum)
[NF] is offline   Reply With Quote
Old   May 8, 2016, 04:18
Default flameletFoam Installation Error After Executing Allwmake
  #22
Thalhah
thalhah90 is on a distinguished road
I tried to install flameletFoam by following the instructions on https://openfoamwiki.net/index.php/E...n/flameletFoam.
At the moment, I have cantera2.0.0 installed and the executable 'flamelet' was successfully created. I believe I was doing fine on the installation up till Section 2.2, the step 'setting an environment variable to the flameletFoam "src"-folder'.
However, when I ran the script ./Allwmake, I got an error message. Since the message is quite long, I'll post just the errors that pop out throughout the message.
//------------------------Start of Message--------------------//
make: *** No rule to make target `Make/linux64GccDPInt32Opt/chemistryReaders/chemkinReader/chemkinLexer.C.dep', needed by `Make/linux64GccDPInt32Opt/chemistryReaders/chemkinReader/chemkinLexer.o'. Stop.
make: *** [/home/user/OpenFOAM/thalhah90-3.0.1/platforms/linux64GccDPInt32Opt/lib/libFlameletchemistryModel.so] Error 1
In file included from LaunderGibsonRSTM/LaunderGibsonRSTM.C:26:0:
LaunderGibsonRSTM/LaunderGibsonRSTM.H:63:32: fatal error: wallDistReflection.H: No such file or directory
#include "wallDistReflection.H"
compilation terminated.
make: *** [Make/linux64GccDPInt32Opt/LaunderGibsonRSTM/LaunderGibsonRSTM.o] Error 1
/home/user/OpenFOAM/flameletFoam/src/turbulenceModels/compressible/LES/compressibleLESdelta/compressibleLESdelta.H:38:22: fatal error: LESdelta.H: No such file or directory
#include "LESdelta.H"
make: *** [Make/linux64GccDPInt32Opt/LESModel/LESModel.o] Error 1
fvOptions/fvOption.C: In member function ‘void Foam::fv:ption::setCellSet()’:
fvOptions/fvOption.C:116:13: error: ‘IInfo’ was not declared in this scope
IInfo<< "- selecting cells using points" << endl;
fvOptions/fvOption.C:144:13: error: ‘IInfo’ was not declared in this scope
IInfo<< "- selecting cells using cellSet " << cellSetName_ << endl;
fvOptions/fvOption.C:153:13: error: ‘IInfo’ was not declared in this scope
IInfo<< "- selecting cells using cellZone " << cellSetName_ << endl;
fvOptions/fvOption.C:171:17: error: ‘IInfo’ was not declared in this scope
IInfo<< "- selecting inter region mapping" << endl;
fvOptions/fvOption.C:216:13: error: ‘IInfo’ was not declared in this scope
IInfo<< "- selecting all cells" << endl;
fvOptions/fvOption.C:241:9: error: ‘IInfo’ was not declared in this scope
IInfo<< "- selected " << returnReduce(cells_.size(), sumOp<label>())
fvOptions/fvOption.C: In constructor ‘Foam::fv:ption:ption(const Foam::word&, const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&, bool)’:
fvOptions/fvOption.C:280:9: error: ‘IInfo’ was not declared in this scope
IInfo<< "- applying source at time " << timeStart_
fvOptions/fvOption.C:285:9: error: ‘IInfo’ was not declared in this scope
IInfo<< "- applying source for all time" << endl;
fvOptions/fvOption.C: In static member function ‘static Foam::autoPtr<Foam::fv:ption> Foam::fv:ption::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)’:
fvOptions/fvOption.C:307:5: error: ‘IInfo’ was not declared in this scope
IInfo<< "Selecting finite volume options model type " << modelType << endl;
make: *** [Make/linux64GccDPInt32Opt/fvOptions/fvOption.o] Error 1
/opt/openfoam30/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:35: fatal error: cyclicAMILduInterface.H: No such file or directory
#include "cyclicAMILduInterface.H"
make: *** [Make/linux64GccDPInt32Opt/YSLFModel/YSLFModels.o] Error 1
//------------------------End of Message--------------------//
Anybody has any idea why these errors occur?
I am running OpenFOAM2.3.0 (beginner user) on Ubuntu 14.04LTE if that bit of info helps. Also, if the full message is required, please let me know.
Thank you in advance for any help.
Regards,
Thalhah
thalhah90 is offline   Reply With Quote
Old   May 8, 2016, 07:44
Hagen Müller
Hagen is on a distinguished road
Dear Thalhah,
did you make sure to source OF2.3 before installing flameletFoam? There are some OF3.0 paths in your log file.
Regards, hagen
Hagen is offline   Reply With Quote
Old   May 8, 2016, 10:40
Thalhah
Dear Hagen,
Ahah..my mistake! My current version of OF is 3.0. I guess that's where the problem is.
In your email, one of the suggestions is changing the code to fit OF3.0 but I'm not entirely sure how to do that since I'm still quite new to OF.
Anyway, I think I shall have to install OF 2.3. I will let you know if that works. Thanks.
Regards,
Thalhah
Old   May 12, 2016, 03:06
Thalhah
After installing an older version of OpenFOAM (OF 2.3.0), I had success on executing Allwmake.
Now that I have cantera and flameletFoam installed, i wanted to use the canteraToFoam utility. However, after running blockMesh, and after typing:
canteraToFoam
in the terminal (in ~/OpenFoam/flameletFoam/tutorial/pilotDiffusionFlame/les directory), an error message appears:
canteraToFoam: command not found
This may sound like a basic question, but how do I tackle this error and get the canteraToFoam utility working?
Thanks in advance for any help!
Old   May 23, 2016, 13:58
elainest is on a distinguished road
hi,
I have the same problem with thalhah90.
In the terminal (in ~/OpenFoam/flameletFoam/tutorial/pilotDiffusionFlame/les directory), canteraToFoam: command not found.
Could anyone help us?
Thanks in advance!
elainest is offline   Reply With Quote
Old   June 1, 2016, 08:26
Yedukrishnan P
yedu is on a distinguished road
Same problem as above. Can anyone help please. Also, blockMesh is creating erroneous log files for canteraToFoam.
yedu is offline   Reply With Quote
Old   June 7, 2016, 23:45
Thalhah
I finally have flameletFoam working!
Installing OpenFoam 2.1.x instead of 2.3.0 apparently solves the problem.
Not sure why the latter version didn't work though..
Old   June 8, 2016, 04:47
Yedukrishnan P
So, does flameletFoam and cantera work in 2.1.x as well?
Old   June 8, 2016, 07:08
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Of course, if not, you have do manipulate the code that it works.
Alternatively you can use the flameletModel based on the research by CRECK Modelling. Check out my homepage for further information, I converted it to different versions and made further improvements.
PS: Cantera does not belong to FOAM.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   June 9, 2016, 01:40
Thalhah
Yedu-Yes. flameletFoam could successfully run once the canteraToFoam utility works. Cantera works OK. It was able to generate the flamelet library regardless of the OF version.
Tobi-Thank you for sharing the page. I guess there's a lot more to explore
Old   June 10, 2016, 04:55
Yedukrishnan P
Hey,
Which cantera version is preferred? flameletFoam compilation guide says cantera 2.0.0. Should I stick with the guide or should I go ahead and install the latest version?
P.S : Thanks Tobi for the link. It sure has lots of interesting things.
Old   June 10, 2016, 05:22
Tobi's Avatar
Tobias Holzmann
I just saw this.
Why it is not working is due to the fact that they changed classes and the therefore you have to check out the code of Hagen and change it to the actual version. As far as I saw in the past, he implemented hard-coded stuff in the turbulence models (not the best solution). Hence, you have to manipulate all stuff that he made not dynamically.
Keep foaming,
Tobias Holzmann
Old   June 10, 2016, 07:05
Yedukrishnan P
I tried Openfoam 2.1.0. But still when I execute canteraToFoam, it says command not found.
Old   June 10, 2016, 07:23
Tobi's Avatar
Tobias Holzmann
Here you did either not compile the stuff correctly or link the program to your $PATH variable.
Normally if you compile it, it will pushed to the $WM_PROJECT_USER_DIR and therefore (after oyu load the FOAM variables) it will add this to your path. If the compilation is not correct, no program will be generated and hence there is no program to execute
To check it easily:
cante «« now double tab it
If you get no auto completion or even a list of available programs that start with »cante«, then there is no program called »canteraToFoam«
Keep foaming,
Tobias Holzmann
Old   June 10, 2016, 09:37
Thalhah
Originally Posted by yedu View Post
Hey,
The flameletFoam that I was able to install works with Cantera2.0.0 (as recommended by the guide).
Old   June 10, 2016, 09:52
Hagen Müller
Dear Thalhah, Dear Yedo,
if you want to use flameletFoam with OpenFOAM-2.3.0, you need to install the correct version that is located here: https://github.com/flameletFoam/flameletFoam-2.3.0/
As Tobi pointed out, we made some changes in the libraries which is why you need another version, if you want to use flameletFoam with OpenFOAM-2.1.0. This version is provided here: https://github.com/flameletFoam/flameletFoam-2.1.x/
The script for cantera is a different story. We tested it with cantera 2.0.0. That's why we recommend to use this version. However, it has nothing to do with the OpenFOAM version you are using.
Regards,
Hagen
dokeun, Tobi, thalhah90 and 1 others like this.
Old   June 10, 2016, 10:08
Tobi's Avatar
Tobias Holzmann
Dear Hagen,
just on question. Will your library be extended in feature, or are you still programming the flamelet-model you used, like non-adiabatic conditions, radiation model implementation etc.?
As far as I know, the flamelet model introduced by CRECK-Modeling is not anylonger available on the official homepage (I used that model during my thesis in detail, thats the reason why I know everything about that model instead of yours ) -- in any case. The problem was that there is no further development (especially for publicity). They introduced the new laminarFoam but I am not sure if that can handle turbulence as well as before (I don't think so).
Thanks in advance,
Keep foaming,
Tobias Holzmann
Old   June 10, 2016, 14:37
Yedukrishnan P
Hey Tobi,
I think the problem is with linking cantera. How do I know if it is linked to the path? When I execute ./Allwrun on a tutorial case in flameletFoam, the log files are created. But the log.canteraToFoam says command not found. I checked in the flameletFoam folder. Inside applications/utilities/preProcessing, there is a folder CanteraToFoam with all the necessary files. But somehow it is not getting linked. What should I do?
Old   June 10, 2016, 15:09
Default error while using 'make' command
  #40
Jaspreet Singh
Jaspreet Singh is on a distinguished road
I have installed Cantera 2.0.0 in OpenFoam 2.3.0.
While running the 'make' to make executable file (.exe), I am getting an error-
g++ flamelet.o StFlow_2.o TransportFactory_2.o Lewis1Transport.o -lf2c -pthread -L/opt/cantera/lib -lcantera -lsundials_cvodes -lsundials_ida -lsundials_nvecserial -lblas -llapack -o flamelet
/opt/cantera/lib/libcantera.a(funcs.os): In function `Cantera:: polyfit(int, double*, double*, double*, int, int&, double, double*)':
/home/jaspreet/Downloads/cantera-2.0.0/src/numerics/funcs.cpp:151: undefined reference to `dpolft_'
/home/jaspreet/Downloads/cantera-2.0.0/src/numerics/funcs.cpp:157: undefined reference to `dpcoef_'
collect2: ld returned 1 exit status
make: *** [flamelet] Error 1
Thanks in advance
Jaspreet Singh is offline   Reply With Quote
[flameletFoam] new flameletFoam for OpenFoam-2.3.0 Likun OpenFOAM Community Contributions 25 April 10, 2017 04:05
[flameletFoam] Issue: Installation of flameletfoam Raghuveera OpenFOAM Community Contributions 2 April 12, 2016 23:59
FlameletFoam tables and OpenFOAM-2.3.x Look-Up-Tables Sermengi OpenFOAM 2 December 19, 2014 07:10
flameletFoam for mutiphase Combustion wenxu OpenFOAM 0 December 10, 2014 09:14
data on flow Hagen Poisseuis kostas FLUENT 0 August 6, 2003 18:37
