[SOWFA] SOWFA windPlantSolver error - "dimensions of phi are not correct"
Old   November 28, 2014, 05:28
Default SOWFA windPlantSolver error - "dimensions of phi are not correct"
Thomas Schulz
cico0815 is on a distinguished road
Hello!
I am new to the usage of the SOWFA solver suite (they are considered still alpha, but I would like to see some results).
I set up a small case and after using blockMesh I started the "windPlantSolver" which produces the following error. I would like to ask if someone could explain the exact meaning of this error and how it could occur. Is this due to changes in OpenFOAM 2.3.0 with respect to older versions of OpenFOAM? Wouldn't this error occur if I use an older version of OpenFOAM?
Here is the copy from my terminal window ...
Starting time loop
Time = 0.05    Time Step = 1
Courant Number mean: 12.667 max: 25
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 5.0422e-09, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 2.9278e-07, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 3.8465e-07, No Iterations 2
DILUPBiCG:  Solving for T, Initial residual = 1, Final residual = 8.5067e-06, No Iterations 5
--> FOAM FATAL ERROR:
    From function backwardDdtScheme<Type>::fvcDdtPhiCorr
    in file finiteVolume/ddtSchemes/backwardDdtScheme/backwardDdtScheme.C at line 795.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::fv::backwardDdtScheme<Foam::Vector<double> >::fvcDdtPhiCorr(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
 at ??:?
 at ??:?
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Any help would be great!
Thanks a lot!
Best, Thomas
cico0815 is offline   Reply With Quote
phi -= pEqn.flux() vs. linearInterpolate(U) & mesh.Sf() santiagomarquezd OpenFOAM Programming & Development 33 October 15, 2019 11:24
Correction procedure on a non-orthogonal skewed Mesh me.ouda OpenFOAM Programming & Development 0 January 18, 2017 10:05
error in 2.3.0 - Dimensions of phi are not correct anuragm OpenFOAM Programming & Development 12 November 30, 2014 01:16
interFoam | Hydraulic Jump | Correct boundary condition p_rgh pythag0ra5 OpenFOAM Running, Solving & CFD 17 September 5, 2014 05:31
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
