[PyFoam] Plotting values (e.g. residuals) from all iterations with pyFoam
Old   November 10, 2014, 08:52
Default Plotting values (e.g. residuals) from all iterations with pyFoam
chriss85 will become famous soon enough
I'm wondering if it is possible to have pyFoam plot residuals (or other values) during each iteration step. So far, I have only found out how to plot the values once each time step (depending on the accumulation property in customRegexp).
Alternatively, I can modify the solver so it prints time steps instead of iteration numbers, but this is not really a proper solution.
I know there are various other methods for plotting residuals, I'd just prefer to have one solution that works for all cases.
chriss85 is offline   Reply With Quote
Old   November 10, 2014, 18:20
Assistant Moderator
Bernhard Gschaider
You're a bit vague about "each iteration step". Iteration of the linear solver? SIMPLE/PISO-iteration?
If you mean "I have multiple instances of solving psi per timestep and want to visualize them all": online plotting won't work. But you can write out files (from the help of pyFoamPlotRunner.py)
Data files
How data files are written
--single-data-files-only
                        Don't create consecutive data files 'value',
                        'value_2', 'value_3' etc but put all the data into a
                        single file
--write-files           Writes the parsed data to files
One of the reasons why there is no plotting of multiple residuals is: how do you assign t to them on the t-axis?
- all the same time? Doesn't look good and gives no indication of progress (that is what single-data-files will give you)
- distribute evenly between this and next time? Problem is that from "outside" (and that is from where PyFoam looks) there is no way to tell how many iterations there are going to be
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 11, 2014, 03:54
In my case I'm talking about PIMPLE/PISO loop.
You're right about the axis of course, but I think in such a case a simple counter would suffice. Using gnuplot, one could probably go more advaned, draw vertical lines and such, but I don't think this is really needed.
It would also be useful if it was possible to specify the regular expression of the loop iteration log file output manually. This way, plotting iterations of custom loops would also be possible.
Old   November 11, 2014, 06:38
Assistant Moderator
Bernhard Gschaider
As I said: the data can be written to file. And then you can do what you want with it.
I won't do it in online plotting because the algorithm that collects data for that and "coarsens" it (to make sure that runs with thousands of timesteps don't use all the CPU just for plotting) assumes that there is only one data item for each timestep
I'm not quite sure what you mean with "specify manually". Of course you can target the output of the linear solver with your own customRegexp too. Or do you mean something else? Two things that MIGHT help you there are "phases" (see the ReleaseNotes) or modifying in the configuration SolverOutput/timeregexp but I'll stay as vague with the answer as you are in your question
Old   November 11, 2014, 11:35
Indeed, the timeregexp might be what I'm looking for, as it would allow me to plot during each iteration step if I add a counting output during each iteration. I basically meant this setting, but specified for a single plot. This way should be fine though because it prevents having to modify the solver time output.
I didn't know about the configuration file before, thanks for pointing me to it!
Old   November 11, 2014, 12:13
Assistant Moderator
Bernhard Gschaider
OK. But don't override it globally but in LocalConfigPyFoam in the case
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
