[swak4Foam] Using fieldAverage together with swak4foam expressionField
Like Tree18Likes
Old   December 14, 2016, 04:38
Exclamation problem was generic, a general solution required
  #21
a
cfd@kgp is on a distinguished road
Dear fgarita,
Thanks for your quick reply.
But the problem was generic, I wanted to multiply 32.0 and again divide by the square of temperature.
my full requirement is,
magSqrGradTinto2
 {  type expressionField;
 outputControl outputTime;
variables (
            "myscalar=32.0;"
            "sqrT=(pow(T,2.0));"
           // "angle=pi/180*(time()<duration ? time()/duration*maxAngle : maxAngle);"
 outputInterval 1;
 fieldName magSqrGradTinto2;
 expression "(magSqr(snGrad(T))) * myscalar / sqrT";
 autowrite true;
and again a similar error,
Creating expression field magSqrGradTinto2 ...
--> FOAM FATAL ERROR:
Parser Error for driver FieldValueExpressionDriver at "1.21-28" :"syntax error, unexpected scalarID"
"(magSqr(snGrad(T)))*myscalar/sqrT"
Context of the error:
- Driver constructed from scratch
Evaluating expression "(magSqr(snGrad(T)))*myscalar/sqrT"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 1210.
FOAM exiting
it will be great to here some solution about this.
Thanks and regards.
cfd@kgp is offline   Reply With Quote
Old   December 14, 2016, 06:42
Agustín Villa
agustinvo is on a distinguished road
Originally Posted by cfd@kgp View Post
Dear fgarita,
magSqrGradTinto2
variables (
            "myscalar=32.0;"
 outputInterval 1;
 autowrite true;
Thanks and regards.
Hi
I think this error can be related with the way you declare the variables. since you have two lines of declaring variables, try to put after "variables" and the first bracket "(" a "2"
agustinvo is offline   Reply With Quote
Old   December 14, 2016, 08:58
a
Originally Posted by agustinvo View Post
Hi
Thanks Agustinvo!
But I could not precisely follow your suggestion "try to put after "variables" and the first bracket "(" a "2""
could you please elaborate?
Old   December 14, 2016, 09:04
Agustín Villa
Thanks Agustinvo!
Hi
something like this:
variables 2 (             "myscalar=32.0;"             "sqrT=(pow(T,2.0));"            // "angle=pi/180*(time()<duration ? time()/duration*maxAngle : maxAngle);"         );
Old   December 14, 2016, 09:13
Unhappy
  #25
a
Hi
Thanks Agustinvo!
I tried your suggestion, it does not help. infact in the expression direct operation of multiplication by 2.0 or infact any other number also fails...
Old   December 14, 2016, 10:11
Default Solved
  #26
a
As it was pointed out by Bernhard in #7
"grad is not available on patches (simply because OF doesn't have it). snGrad is."
I suggest for internalFields snGrad is not available, and grad work smootly.
Old   December 15, 2016, 06:00
Assistant Moderator
Bernhard Gschaider
Dear fgarita,
magSqrGradTinto2
variables (
            "myscalar=32.0;"
 outputInterval 1;
 autowrite true;
Thanks and regards.
The problem is that by default internalField calculates on the cells. And myScalar is therefor a cell-field. snGrad(T) produces a face-field and therefor all subsequent calculations with it are face-values. To combine with a constant value you'll have make that value a face-value. With "interpolate(myscalar/sqrT)".
A bit more about that can be found in the incomplete reference guide with the sources. Look for "native" and "secondary structures" and "Functions that interpolate"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 15, 2016, 06:35
Smile
  #28
a
Thanks gschaider! Information shared is certainly useful...
I will try snGrad along with the interpolate function.
One quick question--> grad() operator calculated gradient by which method? --Guass, least square, etc. can we specify it?
Old   December 15, 2016, 08:20
Assistant Moderator
Bernhard Gschaider
swak4Foam just calls fvc::grad(). Which scheme that function uses is determined by system/fvSchemes
If you want to experiment with discretization schemes: there is a Plugin-Function-Library swakFvcSchemesFunctionPlugin that extends the internalField-parser with a number of functions where you can explicitely choose the discretization scheme for grad() and friends
Old   December 15, 2016, 08:31
Talking
  #30
a
Thanks Bernhard!
Old   December 15, 2016, 09:24
Default swakExpression cannot accept sum(myfl*vol())
  #31
a
Dear Bernhard ,
One more swakExpression gives error while run-time,
[CODE
uysqr
aliases {
myfl sMS1:alpha1; //
type swakExpression;
valueType cellZone;
zoneName solid; // or whatever is your zoneName
accumulations (
min
expression "sum(myfl*(U.y*U.y)*vol())/sum(myfl*1.0*vol())"; // expression "sum((U.y*U.y)*vol()*myfl)/sum(vol()*myfl)";
verbose true;
//outputControlMode timestep
[/CODE]
There is no error "sum(myfl*(U.y*U.y)*vol())/sum(vol())" but it crashes with the following error for "sum(myfl*(U.y*U.y)*vol())/sum(myfl*1.0*vol())"
Expression uysqr : #0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#5 parserSubset::SubsetValueExpressionParser::parse() at SubsetValueExpressionParser.yy.C:?
#6 Foam::SubsetValueExpressionDriver::parseInternal(i nt) at ??:?
#7 Foam::CommonValueExpressionDriver::parse(Foam::exp rString const&, Foam::word const&) at ??:?
#8 Foam::swakExpressionFunctionObject::write() at ??:?
#9 Foam::simpleFunctionObject::execute(bool) at ??:?
#10 Foam::functionObjectList::execute(bool) at ??:?
#11 Foam::Time::run() const at ??:?
#12 ? at ??:?
#13 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#14 ? at ??:?
here myfl is a volscalar field at the cell-centre and vol() scalar firld is also defined at the cell-centres.
Please give your expert opinion..:confused::confused:
Thanks and regards,
Old   December 18, 2016, 07:03
Unhappy
  #32
a
Dear Bernhard,
Please answer my query in post #31.
I am eagerly waiting to hear from you.
Thank,
Old   December 18, 2016, 08:26
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Looks like you've got division by zero here:
sum(myfl*1.0*vol())
Check your myfl
Zeppo is offline   Reply With Quote
Old   December 18, 2016, 08:49
Talking
  #34
a
sum(myfl*1.0*vol())
Check your myfl
Many thanks Zeppo!
fieldaverage, functionobjects, swak4foam
[swak4Foam] problems with averaging a new field fgarita OpenFOAM Community Contributions 1 October 28, 2016 04:27
[swak4Foam] expressionField + execFlowFunctionObjects + AMI pbachant OpenFOAM Community Contributions 0 July 16, 2015 02:09
[swak4Foam] Using swak4foam to implement a BC for heat convection with h(Tamb,Twall) zfaraday OpenFOAM Community Contributions 5 January 19, 2015 15:05
[swak4Foam] expressionField aylalisa OpenFOAM Community Contributions 1 October 28, 2014 18:42
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 14:00
