[swak4Foam] Averaging along an axis.. swak4foam?
Like Tree3Likes
Old   August 7, 2019, 05:24
George Sof
lastjedivol is on a distinguished road
Originally Posted by gschaider View Post
I'm afraid no. There are two ways that new stuff usually gets into swak4foam
  1. I need it for a customer project
  2. Somebody else contributes it
None of these has happened for this feature.
Ok i see, i appreciate your help anyway!
lastjedivol is offline   Reply With Quote
Old   November 3, 2020, 12:47
Bodo1993 is on a distinguished road
Doesn't even write something to postProcessing? I'll have to have a look
Hi Bernhard, I am wondering if you managed to have the look on the proper way to call swakExpressionAverageDistribution as postProcessing after the results are already written. Thanks.
Bodo1993 is offline   Reply With Quote
Old   November 4, 2020, 09:16
Assistant Moderator
Bernhard Gschaider
This is still not implemented (as swak would have to dynamically load every field that is mentioned in the expression)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
averaging, les, swak4foam
[swak4Foam] averaging in spanwise direction of a patch kenny13 OpenFOAM Community Contributions 1 October 3, 2017 11:07
[swak4Foam] problems with averaging a new field fgarita OpenFOAM Community Contributions 1 October 28, 2016 04:27
Starting field averaging using libFunctionObject after certain time eelcovv OpenFOAM Programming & Development 25 December 7, 2015 23:28
Axis treatment in axisymmetrical problem Jakob1 OpenFOAM Pre-Processing 2 August 25, 2014 04:09
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 14:00
